The Connectivity Experiences table displays connection quality information for the previous 24 hours, and includes the following information for each entry:
Use the controls found at the top of the page to customize your view of the table:
To return to the default view, select X.
Select the start date and time, and then select the end date and time for the period. Select up to 7 days, from 90 days of historical data.
To sort the table results in ascending or descending order according to Site. Hover the mouse to the right of the corresponding column label, and select the
. To change the sort order again, select the
. You can also search for connection quality information by site. Use the Items per page menu to specify the maximum number of results to show, per page.
