Use this task to manually specify VLANs to exclude from Missing VLANs anomaly detection.
- Go to , and select
. - Select an existing Excluded VLAN ID, and then select
, or select
. - Select Manual.
Alternatively, select CSV Import and choose a CSV file. To dismiss existing false positives for the VLAN that you want to exclude, select Dismiss existing Missing VLANs.
- In the Excluded VLANs field, type the VLAN IDs to exclude, separated by a comma after each ID.
- From the Exclude from Sites menu, select the corresponding check box for each site from which you want to exclude the VLANs specified in Step 4.
- Select ADD.
