Allows the fabric configuration to be turned off.
| auto | Automatically configures fabric flow control based on the priority flow control RX configuration. |
| off | Unconfigures the fabric flow control. |
Auto.
Use this command to turn off fabric configuration or return it to the default auto mode.
The following command turns off the fabric configuration:
configure forwarding flow-control fabric off
The following command returns fabric configuration to the auto mode:
configure forwarding flow-control fabric auto
This command was first available in ExtremeXOS 12.5.
This command is available on ExtremeSwitching X435, X440-G2, X450-G2, X460-G2, X465, and X695 series switches.
