Configures the settings for the flow key(s) for IPv4.
| src-ip | Specifies the source IP address field as part of the flow key. |
| src-port | Specifies the L4 source port field as part of the flow key. |
| dest-ip | Specifies the destination IP address field as part of the flow key. |
| dest-port | Specifies the L4 destination port field as part of the flow key. |
| protocol | Specifies the L4 protocol field as part of the flow key. |
| tos | Specifies the type of service field as part of the flow key. |
All flow keys.
Use this command to specify which of the designated flow-keys to use. This overrides the default which is all keys. The template sent to the Collector (per the IPFIX standard) contains only the keys used. Then, on a per port basis, you can define masks for the IPv4 source and destination address fields, for instance, to aggregate flows based on subnets. (see configure ip-fix ports flow-key ipv4 mask ipaddress)
To unconfigure, use the unconfigure ip-fix flow-key command.
To display the flow keys use the show ip-fix command.
The following command configures IPv4 traffic to use the source IP address and L4 protocol:
# configure ip-fix flow-key ipv4 src-ip protocol
This command was first available in ExtremeXOS 12.5.
This command is available on the ExtremeSwitching X460-G2 series switches.
