Unconfigures the This command is available on the ExtremeSwitching X440-G2, X450-G2, X460-G2, and X465 series switches. operator limit setting and resets the power limit allowed for PDs connected to the specified ports to the default values.
| operator-limit | Specifies to use the default operator limit based on the port's class type (for example, 30W, 60W, 90W). |
| class-based | Specifies to use the configured operator-limit value for the port(s) instead of the powered device's class. |
| all | Specifies all ports. |
| port_list | Specifies one or more slots and ports. |
PoE—15400 mW.
PoE+—30000 mW.
This command unconfigures any previously configured operator limit for the specified ports. It resets the maximum power that any PD can draw to 15400 mW for PoE and 30000 mW for PoE+.
The following command resets the limit on ports 3 to 6 on a switch to the default value of 15400 mW:
unconfigure inline-power operator-limit ports 3-6
The following command configures class-based on port 1:
configure inline-power operator-limit class-based ports 1
This command was first available in ExtremeXOS 11.1.
PoE+ was added in ExtremeXOS 12.5.
The class-based option was added in ExtremeXOS 32.3.
This command is available on the PoE devices listed in Extreme Networks PoE Devices.
