This command configures This command is available on the ExtremeSwitching X440-G2, X450-G2, X460-G2, and X465 series switches. port-level classification power-up mode for Extreme Networks PoE devices that do not support 802.3bt when connecting to switches with 60W/90W PoE ports. ExtremeSwitching platforms support per-port basis configuration.
| classification | Classification power-up mode. |
| 802.3af | IEEE 802.3af 15W mode. |
| 802.3af-high | IEEE 802.3af 30W mode. |
| 802.3pre-at | IEEE 802.3 pre-at 30W mode. |
| 802.3at | IEEE 802.3at 30W mode. |
| 802.3pre-bt | IEEE 802.3 pre-bt 4-pair 60W mode. |
| 802.3bt-type3 | IEEE 802.3bt Type 3 60W mode. |
| 802.3bt-type4 | IEEE 802.3bt Type 4 90W mode. |
| ports | Specifies the port. |
| port_list | Port list separated by a comma or - . |
Depends on the maximum classification level supported by the platform. For example, one switch can have a default classification level of 802.3bt-type4, while another a default classification level of 802.3at.
Use the specified power-up classification instead of the default classification based on port type.
The following command displays all classification options:
# configure inline-power classification ? 802.3af IEEE 802.3af 15W mode 802.3af-high IEEE 802.3af 30W mode 802.3at IEEE 802.3at 30W mode 802.3bt-type3 IEEE 802.3bt Type 3 60W mode 802.3bt-type4 IEEE 802.3bt Type 4 90W mode 802.3pre-at IEEE 802.3 pre-at 30W mode 802.3pre-bt IEEE 802.3 pre-bt 4-pair 60W mode
This command was first available in ExtremeXOS 31.3.
The 802.3af, 802.3af-high, and 802.3pre-at options were added in ExtremeXOS 31.7.
