Edge License Limits
The following table shows supported limits for features in the Edge License.
X590, X620-X (fiber), and X690 are not supported in this version.
Table 1. Supported Limits for Edge License
MetricProductLimit
AAA (local)—maximum number of admin and local user accounts.All platforms, except X43516
Access lists (meters)—maximum number of meters.ExtremeSwitching X440-G21,024 ingress
256 egress
ExtremeSwitching X450-G2, X460-G21,024 ingress
512 egress
ExtremeSwitching X4652,048 ingress
512 egress
ExtremeSwitching X6956,000 ingress
2,000 egress
Access lists (policies)—suggested maximum number of lines in a single policy file.All platforms, except X435300,000
Access lists (policies)—maximum number of rules in a single policy file.aExtremeSwitching X460-G2, X450-G24,096 ingress
1,024 egress
ExtremeSwitching X440-G22,048 ingress
512 egress
ExtremeSwitching X465, X6958,192 ingress
1,024 egress
Access lists (policies)—maximum number of rules in a single policy file in first stage (VFP).ExtremeSwitching X450-G2, X460-G2, X4652,048 ingress only
ExtremeSwitching X6951,024 ingress only
512 ingress only
Access lists (slices)—number of ACL slices.ExtremeSwitching X460-G2, X450-G216 ingress
4 egress
ExtremeSwitching X465, X69512 ingress
4 egress
ExtremeSwitching X440-G28 ingress
4 egress
Access lists (slices)—number of ACL slices in first stage (VFP).ExtremeSwitching X450-G2, X460-G2, X465, X440-G2, X695 4 ingress only
ACL Per Port Meters—number of meters supported per port.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69516
ACL port ranges.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69532
Meters Packets-Per-Second Capable.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695Yes
AVB (audio video bridging)—maximum number of active streams.ExtremeSwitching X450-G2, X460-G2, X440-G21,024
ExtremeSwitching X465, X6954,096
BFD sessions (Software Mode)—maximum number of BFD sessions.ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X695 (default timers—1 sec) 512
ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X695 (minimal timers—100 msec)10c
BFD IPv4 sessions (Hardware Assisted)—maximum number of IPv4 BFD sessions.ExtremeSwitching X460-G2, X465, X695900 (PTP not enabled)
425 (PTP enabled)
256 (with 3 ms transmit interval)
BFD IPv6 sessions (Hardware Assisted)—maximum number of IPv6 BFD sessions.ExtremeSwitching X460-G2, X465, X695425 (PTP not enabled)
BOOTP/DHCP relay—maximum number of BOOTP or DHCP servers per virtual router.ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X6958
BOOTP/DHCP relay—maximum number of BOOTP or DHCP servers per VLAN.ExtremeSwitching X460-G2, 450-G2, X440-G2, X465, X6958
BOOTP/DHCP relay—maximum number of DHCPv4/v6 relay agentsExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X6954,000
Connectivity fault management (CFM)—maximum number or CFM domains.
Note: With Advanced Edge license or higher.
CFM—maximum number of CFM associations.
ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X695256
CFM—maximum number of CFM up end points.
ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X69532
CFM—maximum number of CFM down end points.
ExtremeSwitching X460-G2256 (non-load shared ports)
32 (load shared ports)
CFM—maximum number of CFM remote end points per up/down end point.
ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X6952,000
CFM—maximum number of dot1ag ports.
ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X695128
CFM—maximum number of CFM segments.
ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X6951,000
CFM—maximum number of MIPs.
CLEAR-Flow—total number of rules supported. The ACL rules plus CLEAR-Flow rules must be less than the total number of supported ACLs.ExtremeSwitching X460-G2, X450-G2 4,094
Data Center Bridging eXchange (DCBX) protocol Type Length Value (TLVs)—maximum number of DCBX application TLVs.ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X6958
DHCPv6 Prefix Delegation Snooping—Maximum number of DHCPv6 prefix delegation snooped entries.ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X695256 (with underlying protocol RIPng)
128 (with underlying protocol OSPFv3)
1,024 (with static routes)
DHCP snooping entries—maximum number of DHCP snooping entries.ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X6952,048
Dynamic ACLs—maximum number of ACLs processed per second.
Note: Limits are load-dependent.
  • with 50 DACLs
  • with 500 DACLs
  • 10
  • 5
EAPS domains—maximum number of EAPS domains.
Note: An EAPS ring that is being spatially reused cannot have more than four configured EAPS domains.
Note: You can increase the number of domains by upgrading to the Advanced Edge license.
ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6954
EAPSv1 protected VLANs—maximum number of protected VLANs.ExtremeSwitching X450-G2, X460-G2, X440-G2-24T/P1,000
ExtremeSwitching X465, X6952,000
ERPS domains—maximum number of ERPS domains with or without CFM configured.
ERPSv1 protected VLANs—maximum number of protected VLANs.ExtremeSwitching X465, X6952,000
ERPSv2 protected VLANs—maximum number of protected VLANs.ExtremeSwitching X450-G2, X460-G2, X465, X6952,000
ExtremeSwitching X440-G2-24T/P500
ELSM (vlan-ports)—maximum number of VLAN ports.
5,000
ExtremeSwitching X440-G2-24T/P4,000
Extended Edge Switching maximum BPEs—maximum number of attached bridge port extenders (BPEs).ExtremeSwitching X46548
Extended Edge Switching maximum cascade ports—maximum number of upstream ports on bridge port extenders (BPEs).ExtremeSwitching X465
2 on V400-24 and V300 models
4 on V400-48 models
Extended Edge Switching maximum tiers—maximum number of cascade levels (tiers) of bridge port extenders (BPEs).ExtremeSwitching X4654
(except for V300-8P-2T-W, which support 1 tier)
Extended Edge Switching maximum ring BPEs—maximum number of bridge port extenders (BPEs) in a ring topology.ExtremeSwitching X4658
Extended Edge Switching maximum VLANs—maximum number of VLANs - Includes all VLANsExtremeSwitching X4654,094
Extended Edge Switching VLAN+ port memberships—maximum number of VLAN+ (extended) port memberships.ExtremeSwitching X465
12,000 in hash mode (default)
131,000 in port-group mode
Forwarding rate—maximum L3 software forwarding rate.ExtremeSwitching X440-G26,460 pps
ExtremeSwitching X450-G2 16,000 pps
ExtremeSwitching X46528,497 pps
ExtremeSwitching X460-G217,000 pps
ExtremeSwitching18,162 pps
ExtremeSwitching X69534,813 pps
FDB (unicast blackhole entries)—maximum number of unicast blackhole FDB entries.ExtremeSwitching X460-G2 49,152f
ExtremeSwitching X450-G234,816f
ExtremeSwitching X440-G216,384f
ExtremeSwitching X465278,528f
ExtremeSwitching X695294,912 f
FDB (multicast blackhole entries)—maximum number of multicast blackhole FDB entries.ExtremeSwitching X460-G2, X450-G2, X440-G21,024
FDB (maximum L2 entries)—maximum number of MAC addresses.ExtremeSwitching X460-G2 98,300g
ExtremeSwitching X450-G268,000g
ExtremeSwitching X465, X695278,528g
ExtremeSwitching X695294,912 g
FDB (maximum L2 entries)—maximum number of multicast FDB entries.ExtremeSwitching X465, X6954,096
Identity management—maximum number of Blacklist entries.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695512
Identity management—maximum number of Whitelist entries.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695512
Identity management—maximum number of roles that can be created.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69564
Identity management—maximum role hierarchy depth allowed. ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6955
Identity management—maximum number of attribute value pairs in a role match criteria. ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69516
Identity management—maximum number of child roles for a role.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6958
Identity management—maximum number of policies/dynamic ACLs that can be configured per role.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6958
Identity management—maximum number of LDAP servers that can be configured.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6958
Identity management—maximum number of Kerberos servers that can be configured.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69520
Identity management—maximum database memory size.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695512
Identity management—recommended number of identities per switch.
Note: Number of identities per switch is for a default identity management database size (512 Kbytes) across all platforms.
ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695100
Identity management—recommended number of ACL entries per identity.
Note: Number of ACLs per identity, based on system ACL limitation.
Identity management—maximum number of dynamic ACL entries configured as an individual dynamic rule, or as an ACL entry in a policy file.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695500
IGMP snooping per VLAN filters—maximum number of VLANs supported in per-VLAN IGMP snooping mode.ExtremeSwitching X460-G2, X6951,500
ExtremeSwitching X450-G2 2,048
ExtremeSwitching X440-G21,000
ExtremeSwitching X4654,000
IGMPv1/v2 SSM-map entries—maximum number of IGMPv1/v2 SSM mapping entries.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695500
IGMPv1/v2 SSM-map entries—maximum number of sources per group in IGMPv1/v2 SSM mapping entries.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69550
IGMPv2 subscriber—maximum number of IGMPv2 subscribers per port.nExtremeSwitching X465, X695, X460-G2, X450-G24,000
ExtremeSwitching X440-G23,500
IGMPv2 subscriber—maximum number of IGMPv2 subscribers per switch.nExtremeSwitching X460-G2, X450-G220,000
ExtremeSwitching X440-G217,500
ExtremeSwitching X465, X69545,000
IGMPv3 maximum source per group—maximum number of source addresses per group.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695250
IGMPv3 subscriber—maximum number of IGMPv3 subscribers per port.nExtremeSwitching X440-G23,500
ExtremeSwitching X460-G2, X450-G2, X465, X6954,000
IGMPv3 subscriber—maximum number of IGMPv3 subscribers per switch.nExtremeSwitching X460-G2, X450-G220,000
IP ARP entries in software—maximum number of IP ARP entries in software.
Note: Might be limited by hardware capacity of FDB (maximum L2 entries).
ExtremeSwitching X460-G2 57,344 (up to)h
ExtremeSwitching X450-G2 47,000 (up to)h
ExtremeSwitching X440-G220,480
ExtremeSwitching X465157,694 (up to) h
ExtremeSwitching X695184,318 (up to) h
IPv4 ARP entries in hardware with minimum LPM routes—maximum recommended number of IPv4 ARP entries in hardware, with minimum LPM routes present. Assumes number of IP route reserved entries is 100 or less.ExtremeSwitching X460-G2 50,000 (up to)h
ExtremeSwitching X450-G239,000 (up to)h
ExtremeSwitching X465119,000 (up to) h
ExtremeSwitching X695146,000 (up to) h
IPv4 ARP entries in hardware with maximum LPM routes—maximum recommended number of IPv4 ARP entries in hardware, with maximum LPM routes present. Assumes number of IP route reserved entries is “maximum.”ExtremeSwitching X460-G2 43,000 (up to)h
ExtremeSwitching X450-G229,000 (up to)h
ExtremeSwitching X465109,000 (up to) h
ExtremeSwitching X695125,000 (up to) h
IP flow information export (IPFIX)—number of simultaneous flows.ExtremeSwitching X460-G2 2,048 ingress
2,048 egress
ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695N/A
IPv4 remote hosts in hardware with zero LPM routes—maximum recommended number of IPv4 remote hosts (hosts reachable through a gateway) in hardware when LPM routing is not used. Assumes number of IP route reserved entries is 0, and number of IPv4 ARP entries present is 100 or less.ExtremeSwitching X460-G2 73,000h
ExtremeSwitching X450-G261,000 (up to)h
ExtremeSwitching X465216,000 (up to) h
ExtremeSwitching X695241,000 (up to) h
IPv4 routes—maximum number of IPv4 routes in software (combination of unicast and multicast routes), including static and from all routing protocols.ExtremeSwitching X460-G2, X450-G2, X440-G225,000
ExtremeSwitching X465, X695131,000
IPv4 routes (LPM entries in hardware)— number of IPv4 routes in hardware.ExtremeSwitching X460-G212,000
ExtremeSwitching X450-G216,000
ExtremeSwitching X465, X695131,000 q
ExtremeSwitching X440-G2480
IPv6 6in4 tunnel—maximum number of IPv6 6in4 tunnels.ExtremeSwitching X450-G2, X460-G2, X465, X695255
ExtremeSwitching X440-G2N/A
IPv6 6to4 tunnel—maximum number of IPv6 6to4 tunnels.ExtremeSwitching X450-G2, X460-G2, X465, X6951 (per virtual router)
IPv6 addresses on an interface—maximum number of IPv6 addresses on an interface.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695255
IPv6 addresses on a switch—maximum number of IPv6 addresses on a switch.ExtremeSwitching X460-G2, X450-G2, X465, X695 2,048
ExtremeSwitching X440-G2510
IPv6 host entries in hardware—maximum number of IPv6 neighbor entries in hardware.ExtremeSwitching X460-G2, 22,000h
ExtremeSwitching X450-G212,000h
ExtremeSwitching X46524,500 s
ExtremeSwitching X69557,000 h
IPv6 routes in software—maximum number of IPv6 routes in software, including static routes and routes from all routing protocols.ExtremeSwitching X450-G2, X460-G2, X440-G225,000
ExtremeSwitching X465, X69565,000q
IPv6 routes (LPM entries in hardware)—maximum number of IPv6 routes in hardware.ExtremeSwitching X460-G26,000
ExtremeSwitching X450-G28,000
65,000q
ExtremeSwitching X440-G2240
IPv6 routes with a mask greater than 64 bits in hardware—maximum number of such IPv6 LPM routes in hardware.ExtremeSwitching X465, X6958,192r
ExtremeSwitching X450-G2, X460-G22,048
IPv6 route sharing in hardware—route mask lengths for which ECMP is supported in hardware.ExtremeSwitching X460-G2, X450-G2
0–64
>64 single path only
ExtremeSwitching X465, X6950–128r
ExtremeSwitching X440-G2Not supported
IP router interfaces—maximum number of VLANs performing IPv4 and/or IPv6 routing. Excludes sub-VLANs.ExtremeSwitching X460-G2,X450-G2, X465, X695 2,048
IP multicast static routes—maximum number of permanent multicast IP routes.ExtremeSwitching X460-G2, X450-G2, X465, X6951,024
IP unicast static routes—maximum number of permanent IP unicast routes.ExtremeSwitching X460-G2, X450-G2, X465, X6951,024
IP route sharing (maximum gateways)—Configurable maximum number of gateways used by equal cost multipath OSPF, BGP, IS-IS, static routes, or L2VPNs. Static routes, OSPF, and BGP are limited to 64 ECMP gateways per destination, while IS-IS is limited to 8. L2VPNs are limited to 16 LSPs per pseudowire on platforms that support 32 gateways, and 64 LSPs per pseudowire on platforms that support 64 gateways.ExtremeSwitching X460-G2, X450-G2, X465, X6952, 4, 8, 16, 32, or 64
IP route sharing (total combinations of gateway sets)—maximum number of combinations of sets of adjacent gateways used by multipath OSPF, BGP, IS-IS, or static routes.ExtremeSwitching X460-G2, X450-G2
  • if maximum gateways is 2
  • if maximum gateways is 4
  • if maximum gateways is 8
  • if maximum gateways is 16 (default)
  • if maximum gateways is 32
  • if maximum gateways is 64
  • 1,022
  • 1,022
  • 510
  • 254
  • 126
  • 62
Note: The values here represent the maximum attainable ECMP groups of which, due to the RIOT feature, half are reserved for overlay and half for underlay routing. For more information about RIOT, see ExtremeXOS v33.2.1 User Guide .
  • 4,094
  • 4,094
  • 2,046
  • 1,022
  • 510
  • 254
ExtremeSwitching X870
  • 2,046
  • 2,046
  • 2,046
  • 1,022
  • 510
  • 254
IP multinetting (secondary IP addresses)—maximum number of secondary IP addresses per VLAN.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695255
Jumbo frames—maximum size supported for jumbo frames, including the CRC.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6959,216
Layer-2 IPMC forwarding caches—(IGMP/MLD/PIM snooping) in mac-vlan mode.
Note:
  • The internal lookup table configuration used is "l2-and-l3”.
  • IPv6 and IPv4 L2 IPMC scaling is the same for this mode.
  • Layer-2 IPMC forwarding cache limits—(IGMP/MLD/PIM snooping) in mixed-mode are the same.
ExtremeSwitching X69573,000
ExtremeSwitching X460-G2 24,000
ExtremeSwitching X450-G214,000
ExtremeSwitching X440-G25,000
ExtremeSwitching X46567,000
Layer-3 IPv4 Multicast—maximum number of <S,G,V> entries installed in the hardware (IP multicast compression enabled).
Note:
  • Limit value is the same for MVR senders, PIM Snooping entries. PIM SSM cache, IGMP senders, PIM cache.
  • Assumes source-group-vlan mode as look up key.
  • Layer 3 IPMC cache limit in mixed mode also has the same value.
ExtremeSwitching X460-G2 26,000
ExtremeSwitching X450-G221,000
ExtremeSwitching X440-G21,500
ExtremeSwitching X46593,000
ExtremeSwitching X695104,000
Layer-3 IPv6 Multicast—maximum number of <S,G,V> entries installed in the hardware (IP multicast compression enabled).
Note:
  • Limit value is the same for MLD sender per switch, PIM IPv6 cache.
  • Assumes source-group-vlan mode as lookup key.
ExtremeSwitching X460-G214,000
ExtremeSwitching X450-G210,000
ExtremeSwitching X440-G2700
ExtremeSwitching X46548,000
ExtremeSwitching X69552,000
Load sharing—maximum number of load sharing groups.
Note: The actual number of load-sharing groups that can be configured is limited by the number of physical ports present in the switch or SummitStack.
ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695128
Load sharing—maximum number of ports per load-sharing group. For standalone and stacked: ExtremeSwitching X440-G28
For standalone: ExtremeSwitching X460-G2, X450-G2, X465, X69532
For stacked: ExtremeSwitching X460-G2, X450-G2, X465, X69564
Logged messages—maximum number of messages logged locally on the system.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69520,000
MAC-based security—maximum number of MAC-based security policies.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6951,024
MAC Locking—Maximum number of MAC locking stations that can be learned on a port.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695
64 (static MAC locking stations)
600 (first arrival MAC locking stations)
Meters—maximum number of meters supported.ExtremeSwitching X460-G2, X450-G2, X440-G2 , X465, X6952,048
Maximum mirroring instances.ExtremeSwitching X450-G2, X460-G2, X465, X695
TableOtherOnly two or four mirroring instances will be active at a time, depending on the mirroring filter added to it. There are four hardware resource slots. Each single instance uses one such slot, while each ingress plus egress instance uses two slots. You can use a total of four slots, while there are no more than two egress instances. The maximum possible combination for mirroring instances:
  1. 4 ingress
  2. 3 ingress + 1 egress
  3. 2 ingress + 2 egress
  4. 2 (ingress + egress)
  5. 1 (ingress + egress) + 2 ingress
  6. 1 (ingress + egress) + 1 egress + 1 ingress
16 (including default mirroring instance)
Note: For stacks containing X440-G2, maximum supported egress mirror instances is 1.
1 (egress)
Mirroring (filters)—maximum number of mirroring filters.
Note: This is the number of filters across all the active mirroring instances.
Mirroring, one-to-many (filters)—maximum number of one-to-many mirroring filters.
Mirroring, one-to-many (monitor port)—maximum number of one-to-many monitor ports.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69516
MLAG ports—maximum number of MLAG ports allowed.
Note: The number of MLAG ports that can be configured is limited by the number of physical ports present in the system.
ExtremeSwitching X69561
ExtremeSwitching X440-G2, X450-G251
ExtremeSwitching X460-G253
ExtremeSwitching35
ExtremeSwitching X46555
Stacking480
MLAG peers—maximum number of MLAG peers allowed.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6952
Multicast listener discovery (MLD) snooping per-VLAN filters—maximum number of VLANs supported in per-VLAN MLD snooping mode.ExtremeSwitching X460-G2 768
ExtremeSwitching X450-G2508
ExtremeSwitching X440-G2256
ExtremeSwitching X465, X6951,500
Multicast listener discovery (MLD)v1 subscribers—maximum number of MLDv1 subscribers per port.nExtremeSwitching X450-G2, X460-G24,000
ExtremeSwitching X465, X6954,000
Multicast listener discovery (MLD)v1 subscribers—maximum number of MLDv1 subscribers per switch.nExtremeSwitching X460-G2, X450-G2, X440-G210,000
Multicast listener discovery (MLD)v2 subscribers—maximum number of MLDv2 subscribers per port.nExtremeSwitching X460-G2, X450-G24,000
Multicast listener discovery (MLD)v2 subscribers—maximum number of MLDv2 subscribers per switch.nExtremeSwitching X460-G2, X450-G2, X440-G210,000
Multicast listener discovery (MLD)v2 maximum source per group—maximum number of source addresses per group.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695200
Multicast listener discovery (MLD) SSM-map entries—maximum number of MLD SSM mapping entries.ExtremeSwitching X450-G2, X460-G2, X465, X695500
ExtremeSwitching X440-G250
Multicast listener discovery (MLD) SSM-MAP entries—maximum number of sources per group in MLD SSM mapping entries.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69550
Network Login—maximum number of clients being authenticated on MAC-based VLAN enabled ports.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6951,024
Network Login—maximum number of clients being authenticated with policy mode enabled with TCI overwrite enabled.ExtremeSwitching X450-G2, X460-G2, X4651,024
ExtremeSwitching X695512
Network Login—maximum number of dynamic VLANs.ExtremeSwitching X460-G2, X450-G2, X465, X6952,000
Network Login VLAN VSAs—maximum number of VLANs a client can be authenticated on at any given time.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69510
Network Service Identifiers (NSI)/VLAN mappings—maximum number of VLANs to NSI mappings.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69594
Network Address Translation (NAT) VLANs—maximum number of NAT VLANs. ExtremeSwitching X465, X6954
Network Address Translation (NAT) Sessions—number of NAT sessions supported (non twice-NAT).ExtremeSwitching X465, X6951,023
Node Alias—maximum number of entries per slot.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6958,192
ONEPolicy Dynamic ACL Rules—maximum number of Dynamic ACLs supported via RADIUS VSA 232 per user in Access-List mode.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69564
ONEPolicy Roles/Profiles—maximum number of policy roles/profiles.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69563
ONEPolicy Rules per Role/Profile—maximum number of rules per role/policy.ExtremeSwitching X450-G2, X460-G2IPv6 rules: 256
IPv4 rules: 256
L2 Rules: 184
MAC Rules: 256
ExtremeSwitching X440-G2IPv6 and Mac Rules: 0
Ipv4 Rules: 256 (per switch)
L2 Rules: 184 (per switch)
IPv4 Rules: 512
IPv6 Rules: 512
MAC Rules: 512
L2 Rules: 440
ONEPolicy Authenticated Users per Switch—maximum number of authenticated users per switch only with TCI-Overwrite enabled.ExtremeSwitching X450-G2, X460-G2, X4651,024
StackingDepends on the stack nodes, but the maximum is 65,535.
ONEPolicy Authenticated Users per Switch—maximum number of authenticated users per switch with TCI-Overwrite disabled.
Note: The maximum values assume 75% utilization of VLAN-XLATE hash table.
ExtremeSwitching X46524,576
ExtremeSwitching X460-G2,, X69512,288
ExtremeSwitching X450-G26,144
ExtremeSwitching X440-G21,536
Stacking1,536–65,534
ONEPolicy Authenticated Users per Port per Switch— maximum number of authenticated users per port per switch with TCI overwrite disabled.
ExtremeSwitching X460-G2, X69512,288
ONEPolicy Authenticated Users per Port per Switch— maximum number of authenticated users per port with only with TCI-Overwrite enabled.ExtremeSwitching X450-G2, X460-G2, X4651,024
ONEPolicy Permit/Deny Traffic Classification Rules Types—total maximum number of unique permit/deny traffic classification rules types (system/stack).ExtremeSwitching X450-G2, X460-G2952
ExtremeSwitching X440-G2440
ExtremeSwitching X465, X6951,976
ONEPolicy Permit/Deny Traffic Classification Rules Types—maximum number of unique MAC permit/deny traffic classification rules types (macsource/macdest).ExtremeSwitching X450-G2, X460-G2256
ExtremeSwitching X465, X695512
ONEPolicy Permit/Deny Traffic Classification Rules Types—maximum number of unique IPv6 permit/deny traffic classification rules types (ipv6dest).ExtremeSwitching X450-G2, X460-G2256
ONEPolicy Permit/Deny Traffic Classification Rules Types—maximum number of unique IPv4 permit/deny traffic classification rules (typesipsource / ipdest / ipfrag / udpsourceportIP / udpdestportIP / tcpsourceportIP / tcpdestportIP / ipttl / iptos / iptype).ExtremeSwitching X450-G2, X460-G2, X440-G2,256
ONEPolicy Permit/Deny Traffic Classification Rules Types—maximum number of unique Layer 2 permit/deny traffic classification rules (ethertype/port).ExtremeSwitching X450-G2, X460-G2184
ExtremeSwitching X440-G2184
ExtremeSwitching X465, X695440
OnePolicy Maximum number of rules supported in AccessList mode—maximum number of rules in AcessList mode.ExtremeSwitching X450-G2, X460-G23,000
ExtremeSwitching X440-G2952
ExtremeSwitching X6953,512
ExtremeSwitching X435440
Policy-based routing (PBR) redundancy—maximum number of flow-redirects.
ExtremeSwitching X450-G2, X460-G2, X440-G2 , X465, X695
256o
Policy-based routing (PBR) redundancy—maximum number of next hops per each flow-direct.
32o
Private VLANs—maximum number of subscribers. Assumes a minimum of one port per network and subscriber VLAN.ExtremeSwitching X460-G253
ExtremeSwitching X450-G251
ExtremeSwitching X440-G247
ExtremeSwitching X69571
ExtremeSwitching X46531
Private VLANs—maximum number of private VLANs with an IP address on the network VLAN.
Note: This limit is dependent on the maximum number of private VLANs in an L2-only environment if the configuration has tagged and translated ports.
ExtremeSwitching X460-G2, X465, X6951,024
ExtremeSwitching X450-G2510
ExtremeSwitching X440-G2255
Private VLANs—maximum number of private VLANs in an L2-only environment.ExtremeSwitching X460-G2, X465, X6951,280
ExtremeSwitching X450-G2597
Route policies—suggested maximum number of lines in a route policy file.ExtremeSwitching X460-G2, X440-G2, X465, X69510,000
RIP Learned Routes—maximum number of RIP routes supported without aggregation.ExtremeSwitchingX460-G2, X440-G2, X465, X69510,000
RIP interfaces on a single router—recommended maximum number of RIP routed interfaces on a switch.ExtremeSwitching X460-G2, X450-G2, X465, X695256
ExtremeSwitching X440-G2128
RIPng learned routes—maximum number of RIPng routes.ExtremeSwitching X460-G2, X450-G2, X465, X6953,000
Spanning Tree (maximum STPDs)—maximum number of Spanning Tree Domains on port mode EMISTP.ExtremeSwitching X450-G2, X460-G2, X465, X69564
ExtremeSwitching X440-G232
Spanning Tree PVST+—maximum number of port mode PVST domains.
Note: For all platforms, the maximum number of active ports per PVST domain depends on the maximum number of spanning tree ports supported on given platform. For example, on a switch that supports 256 PVST domains (maximum) and 4,096 STP ports (maximum), the maximum number of active ports per PVST domain would be 16 ports (4,096 ÷ 256).
ExtremeSwitching X460-G2, X450-G2, X440-G2128
ExtremeSwitching X465, X695384
Spanning Tree—maximum number of multiple spanning tree instances (MSTI) domains.ExtremeSwitching X450-G2, X460-G2, X465, X69564
ExtremeSwitching X440-G2, 32
Spanning Tree—maximum number of VLANs per MSTI.
Note: Maximum number of 10 active ports per VLAN when all 500 VLANs are in one MSTI.
ExtremeSwitching X460-G2, X450-G2, X465, X695600
Spanning Tree—maximum number of VLANs on all MSTP instances.ExtremeSwitching X460-G2, X450-G2, X465, X6951,024
ExtremeSwitching X440-G2512
Spanning Tree (802.1d domains)—maximum number of 802.1d domains per port.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6951
Spanning Tree (number of ports)—maximum number of ports including all Spanning Tree domains.ExtremeSwitching X450-G2, X460-G2, X465, X6954,096
Spanning Tree (maximum VLANs)—maximum number of STP-protected VLANs (dot1d and dot1w).ExtremeSwitching X460-G2, X450-G2, X465, X6951,024
ExtremeSwitching X440-G2600
SSH (number of sessions)—maximum number of simultaneous SSH sessions.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6958
Static MAC multicast FDB entries—maximum number of permanent multicast MAC entries configured into the FDB.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6951,024
Syslog servers—maximum number of simultaneous Syslog servers that are supported.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69516
Syslog targets—maximum number of configurable Syslog targets.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69516
Telnet (number of sessions)—maximum number of simultaneous Telnet sessions.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6958
Virtual routers—maximum number of user-created virtual routers that can be created on a switch. ExtremeSwitching X460-G2, X450-G2, X465, X69563
ExtremeSwitching X440-G216 (local-only VRs)
Virtual router forwarding (VRFs)—maximum number of VRFs that can be created on a switch.
Note: * Subject to other system limitations.
ExtremeSwitching X460-G2,X450-G2, X465, X695960 *
ExtremeSwitching X440-G216 (local-only VRFs)
Virtual router protocols per VR—maximum number of routing protocols per VR.ExtremeSwitching X460-G2,X450-G2, X465, X6958
Virtual router protocols per switch—maximum number of VR protocols per switch.ExtremeSwitching X460-G2,X450-G2, X465, X69564
VLAN aggregation—maximum number of port-VLAN combinations on any one superVLAN and all of its subVLANs.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6951,000
VLANs—includes all VLANs.
Note: Only 4,092 user-configurable VLANs are supported. (VLAN 1 is the default VLAN, and 4,095 is the management VLAN, and you may not configure them.)
ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6954,094
VLANs (Layer 2)—maximum number of Layer 2 VLANs.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6954,094
VLANs (Layer 3)—maximum number of VLANs performing IPv4 and/or IPv6 routing. Excludes sub-VLANs.ExtremeSwitching X460-G2,X450-G2, X465, X6952,048
VLAN Port Interfaces (VPIF)—maximum number of VLAN port interfaces.ExtremeSwitching X440-G2, X450-G2, X460-G265,536
ExtremeSwitching X465, X695131,585
VLANs (maximum active port-based)—maximum active ports per VLAN when 4,094 VLANs are configured with the default license.ExtremeSwitching X465, X69532
ExtremeSwitching X440-G228
ExtremeSwitching X460-G226
VLANs (maximum active protocol-sensitive filters)—number of simultaneously active protocol filters in the switch.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695
16
VLAN translation—maximum number of translation VLANs. Assumes a minimum of one port per translation and member VLAN.ExtremeSwitching X460-G2 53
VLAN translation—maximum number of translation VLAN pairs with an IP address on the translation VLAN.
Note: This limit is dependent on the maximum number of translation VLAN pairs in an L2-only environment if the configuration includes tagged and translated ports.
ExtremeSwitching X465, X695 1,024
ExtremeSwitching X450-G2512
VLAN translation—maximum number of translation VLAN pairs in an L2-only environment.ExtremeSwitching X450-G2, X460-G2, X465, X6952,046
VMAN CEP—maximum number of CVIDs.
Note: With 75% hash table utilization.
ExtremeSwitching X450-G26,000
ExtremeSwitching X460-G2,12,000
ExtremeSwitching X46524,000
XML requests—maximum number of XML requests per second.
Note: Limits are dependent on load and type of XML request. These values are dynamic ACL data requests.
ExtremeSwitching X460-G2, X450-G2, X440-G2, X465, X69510 with 100 DACLs
XNV authentication—maximum number of VMs that can be processed (combination of local and network VMs).ExtremeSwitching X460-G2, X465, X6952,048
ExtremeSwitching X450-G2, X440-G21,024
XNV database entries—maximum number of VM database entries (combination of local and network VMs).ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X69516,000
XNV database entries—maximum number of VPP database entries (combination of local and network VPPs).ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6952,048
XNV dynamic VLAN—Maximum number of dynamic VLANs created (from VPPs /local VMs).ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X6952,048
XNV local VPPs—maximum number of XNV local VPPs.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695
2,048 ingress
512 egress
XNV policies/dynamic ACLs—maximum number of policies/dynamic ACLs that can be configured per VPP.ExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695
8 ingress
4 egress
XNV network VPPs—maximum number of XNV network VPPs.pExtremeSwitching X450-G2, X460-G2, X440-G2, X465, X695
2,048 ingress
512 egress
