create msdp mesh-group
create msdp mesh-group mesh-group-name {vr vrname}
Description
Creates an MSDP mesh-group.
Syntax Description
mesh-group-name Specifies the name for the MSDP mesh-group.
vrname Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context.
Default
N/A.
Usage Guidelines
A mesh-group is a group of MSDP peers with fully meshed MSDP connectivity. Create a mesh-group to:
  • Reduce SA message flooding.
  • Simplify peer-RPF flooding.
SA messages received from a peer in a mesh-group are not forwarded to other peers in the same mesh-group, which reduces SA message flooding.
A mesh group name must begin with an alphabetical character and may contain alphanumeric characters and underscores ( _ ), but it cannot contain spaces. The maximum allowed length for a name is 32 characters. For name creation guidelines and a list of reserved names, see Object Names in the ExtremeXOS v33.6.1 User Guide .
The following example creates a mesh-group called "verizon:":
create msdp mesh-group verizon
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the ExtremeXOS v33.6.1 Licensing Guide document.
