You can easily automatically add or replace nodes in an existing stack.
Important
You can only replace a switch with the same switch model, or with a model from the same switch series (family) with the same number of ports, but a different port type.
Connecting a new node to a stack automatically triggers the following tasks in a stack:
Adds New Nodes—When a new switch is connected to a stack, the switch is automatically:
Assigned the lowest available slot number.
Set as stacking master-capability if the stack has only one master-capable switch (the master itself) and the switch is directly connected to the current stack master. Otherwise, the new switch is not made master-capable.
Assigned the stack MAC address.
Rebooted, which then causes the new node to join the stack.
Incompatible ExtremeXOS Check—Checks for and resolves incompatible ExtremeXOS software versions of stack nodes. If the new switch is running an incompatible version, the version is reconciled by running the synchronize {slotslotid} command for that switch causing the new switch to align with the stack master.
You cannot automatically update a switch running ExtremeXOS 30.2 or earlier to ExtremeXOS 30.3 or later due to a file system compatibility issue. If a switch has ExtremeXOS 30.2 or earlier, prior to inserting the switch into the stack topology, you need to manually upgrade the switch (see Upgrading the Software on all Active Nodes).
License Mismatch Check—Checks for and resolves software license mismatches between all master-capable nodes. The following command is issued: configure stacking {node-addressnode-address | slotslot-number} license-levellicense_restriction.
License mismatches due to installing feature licenses cannot be resolved automatically. The node is left in the failed state.
To start automatic node replacement:
Prepare the replacement node:
If the replacement switch is not out of the shipping box, remove any configuration and restore the factory defaults by running the command unconfigure switch {all | erase [all | nvram]} with the all option.
If the replacement switch is going to be the backup node, check for feature license mismatches between it and the master by running show licenses {[slotslot |all]} {detail} on both switches. Install licenses as needed to the replacement node by running the command enable license {software} [key ] or;
install license filefilename for universal platforms.
Power down the replacement switch.
Remove the current node from the stack.
If you are changing to a different port type (for example, 24t → 24p):
On the master, run the command configure slot slotmodulemodule_type, and change the module_type as applicable.
Save the configuration (save configuration {primary | secondary | existing-config | new-config}
Physically connect the new switch to the stack, and power it up. For information about cabling, see the hardware installation guide for your switch.
Configure the switch port and speed for stack communication on the connected port of the new node for ExtremeSwitching X465, X695 series switches by running the command configure stacking-support stack-port [stack-ports | all] selection [native {V40 | V80 | V160 | V200 | V320 | V400 {alternative-configuration | help}} | alternate].
