Users are created by specifying a user name. Enabling the SNMPv3 user access allows an end user to access the MIBs using SNMPv3 user. By deleting users access, the end-user is not able to access the switch/MIBs using SNMPv3 user.
- To create a user, use the following command:
configure snmpv3 add user [[hex hex_user_name | user_name] {engine-id engine_id}] {authentication [[md5 | sha | sha-256 | sha-384 | sha-512] {localized-key auth_localized_key | hex hex_auth_password | auth_password}] {privacy {des | 3des | aes {128 | 192 | 192-legacy | 256 | 256-legacy}} {localized-key priv_localized_key | hex hex_priv_password | priv_password}}} {volatile}
Beginning in release 34.1.1, the sha-256, sha-384, and sha-512 authentication algorithms are supported in addition to md5 and sha.
- To display information about a user, or all users, use the following command:
show snmpv3 user {[[hex hex_user_name] | user_name]}
- To delete a user, use the following command:
configure snmpv3 delete user [all | [[hex
hex_user_name] | user_name] {engine-id
engine_id}]
The SNMPv3 specifications describe the concept of a security name. In the
ExtremeXOS implementation, the user name and security name are identical. In this manual, both terms are used to refer to the same thing.
