Zero Touch Provisioning (ZTP) enables switches "just out of the box" to automatically gain a management IP address and configuration without serial cables and manual configuration. ZTP provides:
IPv4 Link-Local Address
Link-Local addressing (subnet 169.254.x.x) allows a host device to automatically and predictably derive a non-routable IP address for IP communication over Ethernet links.
By configuring the Ethernet management port "just out of the box" with an IP address, a user can connect a laptop directly to the management Ethernet port. If the laptop is not configured with a fixed IP address, it tries to get an IP address from a DHCP server. If it cannot, it assigns its own Link-Local address putting the switch and the laptop on the same subnet. The laptop can then use Telnet or a web browser to access the switch removing the need for the serial cable.
The X435-8T-4S, X435-8P-4S, and X435-8P-2T-W do not have dedicated management ports. You can use front panel ports for management connectivity for these switches.
The IPv4 address format is used to make it simple for a user to determine the switch‘s IP address. The formula is to use the lower 2 bytes of the MAC address as the last two numbers in the Link-Local IPv4 address.
Web browsers accept a hexadecimal value as an IPv4 address. (Microsoft IE displays the URL with the number dot notation 169.254.233.239.)
The web URL is http://0xa9fee9ee or just 0xa9fee9ee
The user documentation directs the customer to access the web browser by typing 0xa9fe followed by the last two number/letter groups in the MAC address found on the switch label. No hexadecimal translation is required.
With this information, you can connect the Ethernet port directly from a laptop to this switch using the temporary Link-Local address. You can communicate via web or Telnet to perform the initial switch configuration, if needed, and no longer needs a serial cable to configure a switch.
DHCP Parameters
If a DHCP server is available, ZTP tries to contact it alternating between the default VLAN and the management Ethernet port. The DHCP server can provide:
If an IP address is provided by a DHCP server on the management port, it replaces the Link-Local management IPv4 address.
If a TFTP server IP address is provided along with the name of a config file, ZTP downloads the config file to the switch. The switch reboots to activate the config file.
For .xos image files, ZTP executes the download image command to update the switch software. The switch does not reboot after the download image command completes.
DHCP Discovery Over Tagged VLANs
To discover Extreme Cloud, DNS queries must be carried over the tagged VLAN. On an unconfigured device, Auto Provisioning is enabled by default. As a result, the device must automatically discover the tagged VLAN DHCP service. During system initialization, an active agent starts and performs the following tasks:
  1. Sends DHCP discover requests on all VLAN tags 2-4094.
  2. Listens for any DHCP offer responses and records the VLAN and port.
  3. For each VLAN that received a DHCP offer then:
    • Creates the VLAN in the operating system.
    • Adds the tagged port to the VLAN.
    • Attempts to resolve the following DNS names: extremecontrol and hac.extremecloudiq.com.
  4. If neither domain name resolves, the system deletes the VLAN. If it finds at least one DHCP or DNS server, it starts the Cloud Connector (ZTP+) application.
Option 43
Option 43 processing does not require an NMS. If a switch receives option43 as part of the DHCP response, it uses the TFTP protocol to transfer files from the specified TFTP server IP address.
Option43 parameters may contain:
  • TFTP Server to Contact
  • Config file to be loaded or script to be run (.xsf or .py)
  • Policy files (.pol)
  • ExtremeXOS image file to be downloaded (.xos)
  • ExtremeXOS XMOD file to be downloaded (.xmod)
  • SNMP trap receiver address for Extreme MIB traps
Multiple file names may be specified in option43. The file names can be either relative path names or a full URL with the IP address of the TFTP server. If relative path names are specified, the TFTP IP address is also required.
File name examples assuming a TFTP server is present with the IP address 10.10.10.1:
Once all of the files specified in option43 have been transferred to the switch, the switch reboots.
Following is a sample Linux DHCP configuration:
option space EXTREME;
option EXTREME.tftp-server-ip code 100 = ip-address;
option EXTREME.config-file-name code 101 = text;
option EXTREME.snmp-trap-ip code 102 = ip-address;
class "Edge-without-POE" {
match if (option vendor-class-identifier = "XSummit");
vendor-option-space EXTREME;
option EXTREME.tftp-server-ip 10.120.89.80;
option EXTREME.config-file-name "XSummit_edge.cfg";
option EXTREME.snmp-trap-ip 10.120.91.89;
class "Edge-SummitX-POE" {
option EXTREME.config-file-name "xSummit_edge.xsf";
subnet 10.127.8.0  netmask 255.255.255.0 {
option routers                  10.127.8.254;
option domain-name-servers      10.127.8.1;
option subnet-mask              255.255.255.0;
pool {
deny dynamic bootp clients;
range 10.127.8.170 10.127.8.190;
allow members of "Edge-without-POE";
allow members of "Edge-SummitX-POE";
Options 66 and 67
Starting with ExtremeXOS 30.6, option 66 and option 67 are supported, which provide TFTP server and bootpfilename for cases when option 43 is not available for ZTP.
TFTPservername from option 66 is only considered when the DHCP header contains option 52 in DHCPOFFER or DHCPACK messages, or when there is no servername in the DHCP header.
Options 66 and 67 are received as DHCP options in a DHCP response by ExtremeXOS.
If option 43 is not present, then ExtremeXOS looks for the TFTP server IP address and bootp file name in options 66 and 67 to load the configurations or update the new image. If option 43, and options 66 and 67 are present, option 43 has higher precedence.
Identifying an Auto Provision Enabled Switch
A switch enabled with auto-provisioning can be identified by its status, which appears in the output of the show auto-provision command.
Manually Configuring the Cloud Connector
In a network where DHCP is unavailable or DNS cannot resolve the hostname "extremecontrol", Cloud Connector can be manually configured using the following commands to connect to ExtremeCloud IQ Site Engine and onboard the device. Auto-Provision must remain enabled for this process. To keep it enabled, do not save the configuration.
configure auto-provision cloud-connector server [vr ( vr_name | none) | ipaddress (ip_address | none)]
vr_name can be VR-Mgmt or VR-Default.
ip_address is the IP address of the ExtremeCloud IQ Site Engine. It can also be used to override the IP address resolved through DNS. To enable or disable the Cloud Connector, use the following commands:
enable auto-provision cloud-connector
disable auto-provision cloud-connector
Auto-bind on Spanning Tree Protocol Domain for Auto-provisioned VLANs
Version 32.5 modifies a Zero Touch Processing – Dynamic Host Configuration Protocol (ZTPDHCP) script to enable auto-bind on Spanning Tree Protocol Domain (STPD) "s0" for auto-provisioned Virtual Local Area Networks (VLAN). This allows the newly created VLAN(s) to participate in “s0” along with the default VLAN.
The ZTPDHCP script enables auto-bind by calling the following CLI command for every VLAN it creates:
enable stpd s0 auto-bind [ {vlan} vid
If during ZTP the path to a DHCP server uses a tagged port, then the ZTPDHCP script auto-provisions a corresponding VLAN and adds the tagged port. This removes the port from STP Domain "s0", which may result in a network loop. Enabling auto-bind for the auto-provisioned VLAN on STPD "s0" provides loop protection.
The log file generated by the ZTPDHCP script logs the event whenever auto-bind is enabled on STPD “s0” for a newly created VLAN.
ZTPStack
The ZTPStack feature runs on the primary node of a stack and detects when new nodes join the stack topology. Once a new node is detected, ZTPStack configures its stacking parameters and reboots it.
If a node fails to join due to a software version mismatch, ZTPStack automatically copies the correct image to the node. It uses the cloning feature to update images across other nodes in the stack. Version mismatches typically occur when using features like push-button stacking or auto-stacking.
ZTPStack also supports Extended Edge Switching autoconfiguration.
For ZTPStack to function, stacking links must be active, which means stacking-support must be correctly configured or auto-discovery must be enabled. Auto-discovery configures stacking-support based on the transceiver and the capabilities of the connected device (refer to the Auto-Discovery for Universal Hardware section in the Configuring Stacked Switches chapter).
ExtremeXOS Image Update
Using ZTP, you can setup a DHCP/TFTP server and connect switches directly to it, possibly via a Layer 2 switch. Switches can then update themselves with an ExtremeXOS generally available software image before being installed into a live network. ZTP DHCP/TFTP Server Setup shows one possible method of upgrading switches by connecting them to a Layer 2 switch. This approach upgrades the switches before being deployed into a network.
A switch enabled with auto provision can be identified by the following:
  • A warning message for the console and each Telnet session is displayed as follows:
    Note:  This switch has Auto-Provision enabled to obtain configuration remotely. Commands should be limited to:
    show auto-provision
    show log
    Any changes to this configuration will be discarded at the next reboot if auto provisioning sends a ".cfg" file.
  • The shell prompt displays: (auto-provision) SummitX #
  • The status appears in the show auto-provision command.
