Install Engine Application
To install the engine application, take the following steps:
- Go to
- From the pane for the application that you want to install, select Install.
- If you have not yet uploaded the application docker image file, you will be prompted to do so.
- The installation time depends on a variety of factors. Be prepared for it to take some time.
A confirmation notice displays after the installation completes. Only one instance is required for the cluster.
