Pods are groups of containers that share networking and storage resources from the same node.
- Provide the following Pod Network configuration settings:
- Pod Network IP Address
- Pod Network CIDR
- Service Network IP Address
- Service Network CIDR
- Select Create Cluster.
The cluster is created. If a cluster existed previously, the cluster connections are reset. Then, you must reinstall the engines for each node in the cluster.
- After the cluster creation process finishes, select Done.
