Universal Compute Platform v5.11.01 User Guide
Administration
System Configuration
Upgrade the Universal Compute Platform
> Schedule an Upgrade
Extreme Networks, Inc. June 25, 2025
Abstract
Preface
Welcome to Universal Compute Platform
Navigating the User Interface
Dashboard
Dashboard Overview
Deployment Health
System Health Dashboard
Nodes Dashboard
Pods List
VMI List
Services List
Volumes List
Cluster Settings
Cluster Configuration
Select the Deployment Type
Configure Cluster Node Information
Configure Pod Network Information
Certificates
Generate Certificates
Generate CSR
Prepare to Replace a Node
Replace a Node
Add Node
Engines
Engine Installation Options
ExtremeCloud Edge - Managed Orchestration
Run Readiness Assessment
Install ExtremeCloud IQ Engine
Network Service Configuration
Account Registration
ExtremeCloud Edge - Self-Orchestration
Download Docker Application Image
Upload Docker Application Image
Install Engine Application
Deploy Application Image
Engine Application Settings
Engine Upgrades
Upgrade an Application (Self-Orchestrated)
Tools
Logs
Diagnostics
Administration
Manage User Accounts
Account Settings
Configuration
Run a Backup
Restore Backup File
Schedule a Backup
System Logging
Maintenance
Network Setup
Add Interface
Create New Interface Settings
LAG Interfaces
Configure LAG Ports
Add Static Route
Static Route Properties
Network Time
Cloud Visibility
Add Web Proxy Server
Upgrade Universal Compute Platform Task Flow
Upload Software Image
Copy Image to All Nodes
Upgrade Nodes
Schedule an Upgrade
Kubernetes Upgrade
Upgrade Logs
System Information
Utilities
Schedule an Upgrade
Configure an upgrade schedule for the local
image.
You can schedule an upgrade for the local node only. For clusters, you must configure an upgrade schedule for each node separately from that node.
You can upgrade only one node in the cluster at a given time.
The software image must be uploaded already to the local node.
Go to
Administration
System
Software Upgrade
Select
Schedule
Select the
that you want to use for the upgrade.
From the
Backup System to
drop-down, select the destination for the backup file:
Local
—Backup file is saved locally.
Flash
—Backup file is saved to flash.
No Backup
—No backup file is created.
Assign the following details to the backup:
Backup Filename
that you want to assign.
Timezone
of the appliance.
Time
of the upgrade in 24 hour format HH-MM.
Date
of the upgrade in MM/DD format.
When you supply a Date and Time that is in the past, the schedule is set for the following year at the specified date and time.
Select
Schedule
Repeat this procedure on the other cluster nodes to schedule upgrades for those nodes.
