VRRP Configuration (Optional)
In support of load balancing and high-availability functions, the Universal Compute Platform relies on Virtual Router Redundancy Protocol (VRRP) to provide IP abstraction to key functionality. VRRP is critical in the configuration model.
The following operation settings must be defined as part of the VRRP configuration of member nodes:
In a stand-alone configuration, configure priority and router ID with a numeric value. However, in a stand-alone configuration, the specific value is not important. These attribute definitions are important in a multiple-node configuration.
Services VRRP Configuration
The VRRP configuration relates to the number of services you are exposing. Configure a VRRP IP address (VIP) for each service.
Table 1. Stand-Alone Configuration for Services VRRP Configuration
Single Node (Port #)
Data Port (optional) Node Port IP /CIDR
VLAN VLAN Tagged/Untagged
Port type Physical
VRRP (required)
VRRP IP address (VIP) VIP address
Priority Numeric Value
Router ID ID (1)
