(Optional) Add a Port
You have the option to add a port interface that provides access to the admin interface of the container application. This can be any data interface on the Universal Compute Platform.
After you have defined an engine instance IP address for the container application admin interface, you are able to access that container application from a web browser through the defined IP address.
To add a new port interface, take the following steps:
  1. Navigate to Administration > System > Network Setup.
  2. From the Interfaces pane, select Add New Interface.
  3. Configure the Interface Properties for the port.
    Provide a VIP for each engine instance in your deployment.
    User Interface showing properties window for New Port
    User Interface showing properties window for new port
