The virtual machine configuration file is located under /etc/pve/nodes/<KVM_hostname>/qemu-server/<VM_ID>.conf, where KVM_hostname is the name of the server and VM_ID is the virtual machine ID number configured in Step 4.
args: -chardev socket,id=serial0,port=<console_port_number>,host=0.0.0.0,server,nowait,telnet -device isa-serial,chardev=serial0 watchdog: i6300esb
The serial port is added and configured for network access on a network port specified in the <console_port_number>.
# cat /etc/pve/nodes/KVMSERVER/qemu-server/102.conf agent: 1,freeze-fs-on-backup=0 args: -chardev socket,id=serial0,port=56028,host=0.0.0.0,server,nowait,telnet -device isa-serial,chardev=serial0 balloon: 0 boot: order=scsi0 cores: 4 cpu: host hotplug: usb memory: 8192 name: VE6120K net0: e1000=BA:44:BE:F7:AA:08,bridge=vmbr0 net1: virtio=E2:55:A7:86:0D:FF,bridge=vmbr1,queues=2 net2: virtio=52:AA:44:EB:DC:A0,bridge=vmbr2,queues=2 numa: 0 ostype: l26 scsi0: plain-storage:102/vm-102-disk-0.raw,cache=writeback,size=80G,ssd=1 scsihw: virtio-scsi-pci smbios1: uuid=7a25ec0b-0d9f-4fde-9fe4-821afa5f396f sockets: 1 vga: none vmgenid: 8013433b-e9ed-4249-9604-2c5ebf0a4b74 vmstatestorage: data2 watchdog: i6300esb
# cat /etc/pve/nodes/KVMSERVER/qemu-server/100.conf agent: 1,freeze-fs-on-backup=0 args: -chardev socket,id=serial0,port=56030,host=0.0.0.0,server,nowait,telnet -device isa-serial,chardev=serial0 balloon: 0 boot: order=scsi0 cores: 20 cpu: host hotplug: usb memory: 32768 name: VE6125K net0: e1000=4E:FD:02:4C:C5:19,bridge=vmbr0 net1: virtio=2A:39:7A:E0:8E:92,bridge=vmbr1,queues=4 net2: virtio=56:5D:4A:16:63:AF,bridge=vmbr2,queues=4 numa: 0 ostype: l26 scsi0: data2:vm-100-disk-0,cache=writeback,size=250G,ssd=1 scsihw: virtio-scsi-pci smbios1: uuid=07cd719c-fc03-4d3d-ae36-4a612ebf21cf sockets: 1 vga: none vmgenid: 42f181ea-8ffe-4d9b-ac0b-1f45ddb07698 vmstatestorage: data2 watchdog: i6300esb
Use the following example to find the image location:
qm showcmd <VM_ID> --pretty | grep \\-drive
# qm showcmd 105 --pretty | grep \\-drive -drive 'file=/dev/data2/vm-105-disk-0,if=none,id=drive-scsi0,cache=writeback,format=raw,aio=threads,detect-zeroes=on' \ # qm showcmd 102 --pretty | grep \\-drive -drive 'file=/storage/images/102/vm-102-disk-0.raw,if=none,id=drive-scsi0,cache=writeback,format=raw,aio=threads,detect-zeroe\
xz -dc VE6125K-06.01.01.0001.raw.xz | dd of=/dev/data2/vm-100-disk-0 bs=1M status=progress
xz -dc VE6120K-06.01.01.0001.raw.xz > /storage/images/102/vm-102-disk-0.raw
The VM is ready to launch.
