ExtremeSwitching SLX 9150 Hardware Installation Guide
> General Safety Precautions
Published July 2021
Preface
Getting Help
Providing Feedback
What is New in this Document
Supported hardware and software
Device Overview
Hardware features
Port-side view of the SLX 9150 Switch
Nonport-side view of the SLX 9150 Switch
Device management options
Power Supplies
Precautions specific to power supplies
Power Supplies for Use with Your Switch
750 W AC Power Supply
750 W DC Power Supply
Preparing for the Installation
Meeting Building and Electrical Codes
Setting up the Wiring Closet
Controlling the Temperature
Controlling the Humidity Level
Protecting Your System from ESD (Electrostatic Discharge)
Grounding the Rack
Providing Adequate Space for the Rack
Securing the Rack
Evaluating and Meeting Cable Requirements
Labeling Cables and Keeping Accurate Records
Installing Cable
Handling Fiber Optic Cable
Cable Distances and Types
SFP/SFP+ Cable Distances and Types
Using RJ45 Connector Jackets
Preventing Radio Frequency Interference (RFI)
Meeting Power Requirements
Power Supply Requirements
Requirements for Power Cords
Selecting a UPS
Calculating Volt-Amperage Requirements
Providing a Suitable UPS Transition Time
Following Applicable Industry Standards
Installing Your Switch
Safety Considerations for Installing Switches
Attaching the Switch to a Rack
Attaching the Switch to a Four-Post Rack
Attaching the Switch to a Two-Post Rack
Installing Optional Components
Breakout cables
Installing Internal Power Supplies
Installing a 750 W Internal AC Power Supply
Installing a 750 W Internal DC Power Supply
Required Tools and Materials for Installing a 750 W DC Power Supply
Preparing the Cables for a 750 W DC Power Supply
Connecting the Ground Wire to a 750 W DC Power Supply
Connecting a 750 W DC Power Supply to the Source Voltage
Powering up the Switch
Connecting Network Interface Cables
Activating and Verifying the Switch
Establishing a serial connection
Configuring the Switch for Use
Monitoring the Switch
SLX 9150 Series Switch LEDs
750 W AC Power Supply LEDs
750 W DC Power Supply LEDs
Removing and Replacing Components
Replacing Internal Power Supplies
Replacing Fan Modules
Removing the Switch from the Rack
ExtremeSwitching SLX 9150 Technical Specifications
750 W Power Supplies Technical Specifications
Maintenance Safety
Cable Routing for LAN Systems
Installing Power Supply Units and Connecting Power
Selecting Power Supply Cords
Battery Notice
Regulatory Statements
CE statement
China ROHS
Canadian requirements
China CCC statement
Australia (RCM)
Federal Communications Commission (FCC) Notice
Germany statement
KCC statement (Republic of Korea)
Japan (VCCI Class A)
Japan power cord
Cautions and Danger Notices
Cautions
Danger Notices
Follow these guidelines:
Do not try to lift objects that you think are too heavy for you.
When you install equipment in a rack, load heavier devices in the lower half of the rack first to avoid making the rack top-heavy.
Use only tools and equipment that are in perfect condition. Do not use equipment with visible damage.
Route cables in a manner that prevents possible damage to the cables and avoids causing accidents, such as tripping.
Do not place a monitor or other objects on top of the equipment. The chassis cover is not designed to support weight.
To reduce the risk of fire, use only #26 AWG or larger telecommunications line cord. Use only copper conductors.
Do not work on the system or connect or disconnect cables during periods of lightning activity.
This equipment must be grounded. Never defeat the ground conductor or operate the equipment in the absence of a suitably installed ground conductor.
