Port Mirroring (SPAN)
  Port mirroring, also known as Switched
		Port Analyzer (SPAN), sends copies of packets that enter or exit one port to another
		physical port or LAG interface, where the packets can be analyzed.
		The analyzer is locally connected to the SPAN destination interface of the SLX device. Unlike a
			hub, which broadcasts any incoming traffic to all ports, the SLX device forwards traffic
			accordingly. If you want to snoop on the traffic that passes through a specific port,
			use port mirroring to copy the packets to a port connected to the analyzer.
		You use the monitor session
			command to enable a SPAN session. With this command, you can set the packet source, the
			packet destination, and the packet direction (egress, ingress, or both).
		General considerations
				- Do not configure SPAN destination ports to carry normal traffic.
- Configure only physical interfaces as SPAN
					source. For SPAN destinations, you can configure physical interfaces, LAG, or
					port-channels with manual trunks (with no protocols).
- The maximum number of supported SPAN sessions is 512 per device.
- The standard limitations of forwarding apply to port mirroring when the SPAN
					source and destination interfaces have different speeds. For example, when
					traffic is mirrored from a 40G port to a 10G port, the 10G port drops traffic
					that exceeds the 10G rate.
- In one monitor session configuration, you can
					have only one SPAN source and only one SPAN destination. However, you can share
					the same destination port in another session with different source ports. In
					other words, you can use the same port as a SPAN destination in another SPAN
					session, which lets you have more SPAN sessions without consuming more SPAN
					hardware resources.
 SLX 9150 and  SLX 9250
				considerations
					- The devices support four hardware SPAN sessions.
							- One unique SPAN destination in the session configuration consumes
								one hardware SPAN session.
- Two hardware SPAN sessions are reserved for ACL logging and
								flow-based SPAN sessions.
- Therefore, you can configure two different
								destinations for port mirroring. If you try to configure mirror
								sessions with more than two different destination ports, the
								configuration fails and generates a RASLog message. You have to
								manually remove the failed configuration.
- The application telemetry feature consumes
								one hardware SPAN session. If you configure application telemetry,
								you can configure only one monitor session with a unique destination
								or multiple monitor sessions that share the same SPAN
								destination.
- CPU-generated frames that do not enter the
						ingress pipeline of the ASIC cannot be mirrored by an egress SPAN session
						(an egress SPAN session is enabled on the interface from which the
						CPU-generated frame egresses). Egress SPAN occurs primarily in the ingress
						pipeline at the Memory Management Unit (MMU) stage of the ASIC pipeline. For
						example, a ping that is generated from the device and egresses on a physical
						Layer 3-routed port does not enter the ingress pipeline. The ping cannot be
						mirrored by an egress SPAN session.
- The platforms do not support true egress
						mirroring. If incoming packets are modified and sent to egress ports, some
						fields, such as VLAN and TTL, in the mirrored captured frames are not
						identical to the egress frame.
- Because egress SPAN occurs primarily at the
						MMU stage (which is the last stage of the ingress pipeline of the ASIC),
						mirrored copy is the same as the packet content seen at this stage. Any VLAN
						modifications that occurred before this stage are reflected in the mirror
						copy. However, the original packet can have modifications farther in the
						egress pipeline and those modifications are not reflected in the mirrored
						copy.
- Because egress SPAN occurs in the ingress
						pipeline, the mirroring engine may replicate the egress packets even though
						the original egress packets could be dropped at later stage. This
						replication has various causes, such as the source suppression of unknown
						unicast, broadcast traffic. Source suppression drops unknown traffic before
						it is transmitted out of the ingress port. However, the replication engine
						replicates the traffic when the same ingress port is configured as a SPAN
						source with an egress direction. Therefore, there may not be actual egress
						frames on the SPAN source interface.
		 SLX 9540 and  SLX 9640
				considerations
				- The devices support 15 hardware SPAN
					sessions.
- One unique SPAN destination in the monitor
					session configuration consumes one hardware SPAN session.
- Twelve sessions are reserved for VxLAN
					visibility features, snooping applications, and flow-based SPAN sessions.
- Therefore, you can configure three different
					destinations for port mirroring. If you try to configure mirror sessions with
					more than three different destination ports, the configuration fails and
					generates a RASLog message. You have to manually remove the failed
					configuration.
					one hardware SPAN session. If you configure application telemetry, you can
					configure only two monitor sessions, each with a unique destination, or multiple
					monitor sessions that share one of the SPAN destination.
