Telemetry profiles determine which types of data are collected and parameters that govern the data collection.
For MPLS telemetry-profiles ( SLX 9540 and SLX 9640 only), refer to the "MPLS traffic statistics data streaming" section of the Extreme SLX-OS MPLS Configuration Guide.The following telemetry profile types and profiles are supported:
Of the interface profile-type, the only profile supported is default_interface_statistics. This profile tracks data related to the physical interface. You need to specify monitored interfaces and can modify the default streaming interval.
Of the system-utilization profile-type, the only profile supported is default_system_utilization_statistics. This profile tracks system-related data. You can modify the default streaming interval.
Queue profiles are supported only on the SLX 9540 and SLX 9640 devices.Of the queue profile-type, the only profile supported is default_queue_statistics. This profile tracks data related to the queue. You need to specify monitored interfaces and can modify the default streaming interval.
Of the enhanced-queue-discard-pkts profile-type, the only profile supported is enhanced-queue-discard-pkts. This profile tracks data related to discarded packets. You need to specify monitored interfaces and can modify the default streaming interval.
Of the enhanced-queue-max-queue-depth profile-type, the only profile supported is default_enhanced_queue_max_queue_depth_statistics. This profile tracks data related to maximum queue depth. You need to specify monitored interfaces and can modify the default streaming interval.
The following table summarizes profile support for queue data.
| Profile | Description |
| default_enhanced_queue_discard_pkts_statistics | Captures summary of 32 queues having the most
								number of packets discarded, in descending order of packet discards
								observed. Indexed by interface (slot/port). Data stream contains:
| default_enhanced_queue_max_queue_depth_statistics | Captures summary of 32 queues reaching maximum
								max-queue-size, in descending order. Data stream contains:
| default_queue_statistics | Captures all queue statistics per specified
								interface. Data stream contains:
