Execute the following steps to configure resource monitoring.
		  Enter global configuration mode.
			 device# configure terminal
		  Issue the
			 resource-monitor cpu enable command to enable the CPU utilization monitoring service.
			 device(config)# resource-monitor cpu enable
		  Issue the
			 resource-monitor memory command to enable the system memory monitoring and generate raslog when the memory usage exceeds threshold value.
		  Issue the resource-monitor process memory
			 command to enable the per-process memory monitoring and generate alarm or raslog when the usage exceeds alarms threshold or critical threshold respectively.
		  (Optional) Issue the how running-configuration command to view the resource monitoring running configuration.
