You can customize Opticthresholds or actions by using the threshold-monitor sfp command, which enables you to perform the following tasks.
If you do not provide the Optic type parameters, the default thresholds and actions are used. Optic types, monitoring areas, and default threshold values for the 16-Gbps and QSFP optics are detailed below.
| Optic type | Area | Unit | Low | High |
| 1GSR | Temperature | C | -40 | 100 |
| RX power | uW | 8 | 1122 | |
| TX power | uW | 60 | 1000 | |
| Current | mA | 2 | 12 | |
| Supply voltage | mV | 3000 | 3600 | |
| Power on hours | Hrs | 0 | 0 | |
| 1GLR | Temperature | C | -45 | 90 |
| RX power | uW | 6 | 501 | |
| TX power | uW | 71 | 794 | |
| Current | mA | 1 | 45 | |
| Supply voltage | mV | 2900 | 3700 | |
| 1GCOP | Temperature | C | -45 | 90 |
| 10GUSR | Temperature | C | -5 | 100 |
| RX power | uW | 32 | 2000 | |
| TX power | uW | 126 | 2000 | |
| Current | mA | 3 | 11 | |
| 10GSR | Temperature | C | -5 | 90 |
| RX power | uW | 32 | 1000 | |
| TX power | uW | 251 | 794 | |
| Current | mA | 4 | 11 | |
| 10GLR | Temperature | C | -5 | 88 |
| RX power | uW | 16 | 1995 | |
| TX power | uW | 158 | 1585 | |
| Current | mA | 15 | 85 | |
| Supply voltage | mV | 2970 | 3600 | |
| 10GER | Temperature | C | -5 | 75 |
| RX power | uW | 10 | 1585 | |
| TX power | uW | 135 | 5012 | |
| Current | mA | 20 | 120 | |
| Supply voltage | mV | 3035 | 3665 | |
| 40GSR | Temperature | C | -5 | 75 |
| RX power | uW | 40 | 1995 | |
| TX power | uW | 0 | 0 | |
| Current | mA | 1 | 10 | |
| 40GSRINT | Temperature | C | -5 | 75 |
| RX power | uW | 45 | 2188 | |
| Current | mA | 1 | 55 | |
| Supply voltage | mV | 2970 | 3630 | |
| 40GESR | Temperature | C | -5 | 75 |
| 40GLR | Temperature | C | -5 | 70 |
| RX power | uW | 21 | 3380 | |
| Current | mA | 5 | 70 | |
| 100GSR | Temperature | C | -5 | 75 |
| RX power | uW | 40 | 2188 | |
| TX power | uW | 100 | 3162 | |
| Current | mA | 3 | 13 | |
| 100GLR | Temperature | C | -5 | 75 |
| RX power | uW | 35 | 3548 | |
| TX power | uW | 148 | 5623 | |
| Current | mA | 20 | 110 | |
| 100GPSM | Temperature | C | 0 | 70 |
| RX power | uW | 55 | 2818 | |
| TX power | uW | 398 | 2818 | |
| Current | mA | 30 | 70 | |
| Supply voltage | mV | 3135 | 3465 | |
| 100GCWDM | Temperature | C | -3 | 75 |
| RX power | uW | 45 | 2239 | |
| TX power | uW | 114 | 2818 | |
| Current | mA | 5 | 75 | |
| Supply voltage | mV | 3040 | 3560 | |
| 100GCLR | Temperature | C | 0 | 70 |
| 100GLRLT | Temperature | C | -5 | 75 |
| RX power | uW | 55 | 3548 | |
| TX power | uW | 234 | 3548 | |
| 10GZR | Temperature | C | -11 | 91 |
| RX power | uW | 2 | 51 | |
| TX power | uW | 316 | 3548 | |
| Current | mA | 15 | 130 | |
| Supply voltage | mV | 3000 | 3510 | |
| 1GCWDM | Temperature | C | -9 | 110 |
| RX power | uW | 4 | 1000 | |
| TX power | uW | 398 | 8310 | |
| Current | mA | 2 | 105 | |
| Supply voltage | mV | 2800 | 4000 | |
| 10GDWDMT | Temperature | C | -8 | 73 |
| RX power | uW | 1 | 398 | |
| TX power | uW | 501 | 1995 | |
| Current | mA | 15 | 126 | |
| 40GER | Temperature | C | -5 | 78 |
| RX power | uW | 3 | 2239 | |
| Current | mA | 8 | 105 | |
| 40GLM | Temperature | C | -5 | 78 |
| RX power | uW | 17 | 3388 | |
| 100GESR40GLM | Temperature | C | -5 | 75 |
| RX power | uW | 35 | 2188 | |
| TX power | uW | 74 | 3467 | |
| Current | mA | 2 | 10 | |
| 100GAOC40GLM | Temperature | C | -5 | 75 |
| 1GBIDI10KM | Temperature | C | -40 | 95 |
| RX power | uW | 11 | 501 | |
| TX power | uW | 126 | 501 | |
| Current | mA | 3 | 80 | |
| 1GBIDI40KM | Temperature | C | -40 | 85 |
| RX power | uW | 6 | 1000 | |
| TX power | uW | 316 | 1000 | |
| Current | mA | 0 | 300 | |
| Supply voltage | mV | 3130 | 3470 | |
| 1GBIDI120KM | Temperature | C | -40 | 85 |
| RX power | uW | 1 | 200 | |
| TX power | uW | 794 | 2512 | |
| Current | mA | 0 | 500 | |
| 1GELX | Temperature | C | -10 | 85 |
| RX power | uW | 0 | 5000 | |
| TX power | uW | 0 | 5000 | |
| Current | mA | 0 | 50 | |
| 1GFX | Temperature | C | -40 | 85 |
| TX power | uW | 126 | 794 | |
| 1GLHA | Temperature | C | -5 | 85 |
| RX power | uW | 2 | 1000 | |
| TX power | uW | 794 | 3981 | |
| Current | mA | 2 | 90 | |
| 1GLHB | Temperature | C | -10 | 85 |
| 1GLX | Temperature | C | -40 | 85 |
| RX power | uW | 5 | 1585 | |
| Current | mA | 0 | 60 | |
| 1GLX-1 | Temperature | C | -40 | 85 |
| RX power | uW | 10 | 500 | |
| TX power | uW | 100 | 500 | |
| 1GLXDUAL | Temperature | C | -40 | 95 |
| RX power | uW | 1 | 158 | |
| TX power | uW | 32 | 158 | |
| 1GLXTAA | Temperature | C | -40 | 85 |
| Current | mA | 0 | 90 | |
| 1GLXTAA-1 | Temperature | C | -10 | 100 |
| RX power | uW | 5 | 501 | |
| 1GSX | Temperature | C | -40 | 85 |
| RX power | uW | 31 | 500 | |
| 1GSXTAA | Temperature | C | -40 | 100 |
| RX power | uW | 13 | 1000 | |
| TX power | uW | 158 | 501 | |
| Current | mA | 0 | 20 | |
| 1GZRCWDM | Temperature | C | -40 | 85 |
| RX power | uW | 5 | 1000 | |
| Supply voltage | mV | 3000 | 4000 | |
| 1GZRCWDM-1 | Temperature | C | -40 | 85 |
| 1GZRCWDM-2 | Temperature | C | -40 | 85 |
| 8GELS | Temperature | C | -10 | 85 |
| RX power | uW | 12 | 1122 | |
| TX power | uW | 250 | 2500 | |
| 8GLR | Temperature | C | -10 | 85 |
| TX power | uW | 144 | 1122 | |
| 8GSR | Temperature | C | -40 | 125 |
| RX power | uW | 10 | 1000 | |
| TX power | uW | 100 | 1585 | |
| 8GSR-1 | Temperature | C | -10 | 85 |
| RX power | uW | 49 | 500 | |
| 10GBIDI | Temperature | C | -40 | 85 |
| RX power | uA | 36 | 1122 | |
| TX power | uA | 151 | 1122 | |
| Current | mA | 0 | 65 | |
| Supply voltage | mV | 3100 | 3500 | |
| 10GBIDI40KM | Temperature | C | -40 | 125 |
| RX power | uA | 40 | 1122 | |
| TX power | uA | 1585 | 5012 | |
| Current | mA | 0 | 285 | |
| 10GBIDITAA | Temperature | C | -40 | 125 |
| TX power | uA | 316 | 1000 | |
| Current | mA | 0 | 400 | |
| 10GCWDM-1 | Temperature | C | -10 | 75 |
| RX power | uA | 10 | 1585 | |
| TX power | uA | 316 | 1585 | |
| 10GCWDM-2 | Temperature | C | -10 | 75 |
| 10GER40KM | Temperature | C | ||
| RX power | uA | -10 | 85 | |
| TX power | uA | 0 | 5000 | |
| 10GERDWDM | Temperature | C | -8 | 73 |
| RX power | uW | 20 | 1000 | |
| TX power | uW | 501 | 3162 | |
| Current | mA | 40 | 120 | |
| 10GERDWDM -1 | Temperature | C | -8 | 73 |
| RX power | uA | 20 | 1000 | |
| TX power | uA | 501 | 3162 | |
| 10GERX | Temperature | C | -10 | 85 |
| RX power | uA | 0 | 5000 | |
| 10GET | Temperature | C | -10 | 85 |
| 10GLR10KM | Temperature | C | -5 | 70 |
| RX power | uA | 38 | 1122 | |
| 10GLRDUAL | Temperature | C | -40 | 125 |
| RX power | uA | 6 | 1585 | |
| TX power | uA | 100 | 1585 | |
| 10GLRDUAL -1 | Temperature | C | 0 | 70 |
| RX power | uA | 25 | 1120 | |
| TX power | uA | 151 | 1120 | |
| 10GLRMX | Temperature | C | -10 | 85 |
| 10GLRTAA | Temperature | C | -10 | 90 |
| RX power | uA | 16 | 1259 | |
| TX power | uA | 126 | 1413 | |
| Current | mA | 7 | 100 | |
| 10GSLRM | Temperature | C | -40 | 125 |
| RX power | uA | 6 | 1000 | |
| TX power | uA | 100 | 1995 | |
| Current | mA | 0 | 75 | |
| 10GSLRM-1 | Temperature | C | -25 | 95 |
| RX power | uA | 10 | 1259 | |
| TX power | uA | 158 | 1585 | |
| Supply voltage | mV | 2800 | 3800 | |
| 10GSR300M | Temperature | C | 0 | 70 |
| RX power | uA | 10 | 1000 | |
| TX power | uA | 126 | 562 | |
| Supply voltage | mV | 3140 | 3460 | |
| 10GSR300M-1 | Temperature | C | -10 | 85 |
| RX power | uA | 77 | 500 | |
| TX power | uA | 100 | 500 | |
| 10GSR300M-2 | Temperature | C | -20 | 90 |
| RX power | uiA | 10 | 1259 | |
| TX power | uA | 160 | 1589 | |
| Current | mA | 1 | 20 | |
| Supply voltage | mV | 2800 | 3000 | |
| 10GSR300M-3 | Temperature | C | -5 | 70 |
| 10GSRDUAL | Temperature | C | -40 | 125 |
| RX power | uA | `10 | 1000 | |
| TX power | uA | 100 | 794 | |
| 10GSRDUAL-1 | Temperature | C | -10 | 85 |
| 10GSRTAA | Temperature | C | -10 | 85 |
| 10GSRTAA-1 | Temperature | C | -20 | 90 |
| 10GSRX | Temperature | C | -10 | 85 |
| RX power | uA | 32 | 2000 | |
| TX power | uA | 126 | 2000 | |
| 10GUSR100M | Temperature | C | -5 | 85 |
| TX power | uA | 316 | 794 | |
| 10GUSR100M-1 | Temperature | C | -10 | 85 |
| 10GUSR100MTA | Temperature | C | -5 | 70 |
| Supply voltage | mV | 3140 | 3640 | |
| RX power | uA | 2 | 251 | |
| TX power | uA | 316 | 3548 | |
| 10GZR80KM | Temperature | C | -10 | 75 |
| RX power | uA | 2 | 316 | |
| TX power | uA | 794 | 3162 | |
| Current | mA | 0 | 127 | |
| 10GZRCWDM | Temperature | C | -10 | 85 |
| 10GZRX | Temperature | C | -10 | 85 |
| 25GER | Temperature | C | -10 | 85 |
| 25GESR | Temperature | C | 0 | 70 |
| RX power | uA | 79 | 1738 | |
| TX power | uA | 126 | 1738 | |
| Supply voltage | mV | 3140 | 3450 | |
| 25GLR | Temperature | C | 0 | 70 |
| RX power | uA | 52 | 1585 | |
| TX power | uA | 200 | 1585 | |
| 25GSR | Temperature | C | 0 | 70 |
| 25GSR100M | Temperature | C | 0 | 85 |
| RX power | uA | 40 | 1000 | |
| TX power | uA | 158 | 794 | |
| Supply voltage | mV | 3150 | 3460 | |
| 40GSRBIDI | Temperature | C | 10 | 70 |
| RX power | uW | 170 | 1000 | |
| RX power | uA | 45 | 2188 | |
| TX power | uA | 0 | 0 | |
| 100G4WDM | Temperature | C | -10 | 85 |
| 100GCWDM2KM | Temperature | C | 0 | 70 |
| RX power | uA | 71 | 1778 | |
| TX power | uA | 224 | 1778 | |
| Current | mA | 0 | 100 | |
| Supply voltage | mV | 0 | 3450 | |
| 100GERLT | Temperature | C | -10 | 85 |
| 100GLR10KM | Temperature | C | 0 | 70 |
| RX power | uA | 87 | 2818 | |
| TX power | uA | 372 | 2818 | |
| Supply voltage | mV | 0 | 3465 | |
| RX power | uA | 55 | 3548 | |
| TX power | uA | 234 | 3548 | |
| 100GSR100M | Temperature | C | -10 | 80 |
| RX power | uA | 40 | 3467 | |
| TX power | uA | 62 | 3467 | |
| Current | mA | 0 | 12 | |
| 100GSRBIDI | Temperature | C | -10 | 85 |
| 100MBIDI | Temperature | C | -40 | 95 |
| RX power | uA | 1 | 40 | |
| TX power | uA | 40 | 158 | |
| 100MFX | Temperature | C | -40 | 85 |
| RX power | uA | 62 | 125 | |
| 100MFX-1 | Temperature | C | -10 | 85 |
| 100MLX | Temperature | C | -40 | 95 |
| RX power | uA | 1 | 200 | |
| TX power | uA | 25 | 200 | |
| Current | mA | 0 | 80 | |
