Configuring Active Directory groups on the client side
An Active Directory (AD) group defines access permissions for the LDAP server similar to Extreme roles. You can map an Active Directory group to an Extreme role with the ldap-server maprole command. The command confers all access privileges defined by the Active Directory group to the Extreme role to which it is mapped.
A user on an AD server must be assigned a nonprimary group, and that group name must be either matched or mapped to one of the existing roles on the device.
After successful authentication, the user is assigned a role from a nonprimary group (defined on the AD server) based on the matched or mapped device role.
A user logging in to the device that is configured to use LDAP and has a valid LDAP user name and password will be assigned LDAP user privileges if the user is not assigned a role from any nonprimary group.
