Layer 3 ACL configuration guidelines
We present configuration guidelines for
all ACLs, then for Layer 3 ACLs, then for L3 ACLs applied to a user interface, then for ACLs
applied to the management interface, and then guidelines for receive-path ACLs (rACLs).
The following guidelines are for all ACLs:
- An ACL name can be up to 63 characters
long, and must begin with a–z, A–Z or 0–9. You can also use underscore (_) or
hyphen (-) in an ACL name, but not as the first character.
- On any given device, an ACL name
must be unique among all ACL types (MAC/IPv4/IPv6, standard or extended).
- The order of the rules in an ACL
is critical. The first rule that matches the traffic stops further processing of
the rules. For example, following a permit match,
subsequent deny or hard-drop rules do not override the permit.
- When you create an ACL rule, you have
the option of specifying the rule sequence number. If you create a rule without
a sequence number, it is automatically assigned a sequence number incremented
above the previous last rule.
- To modify an ACL rule, delete it and
then replace it with a rule of the same seq number.
- You can apply a maximum of five ACLs to
a user interface, as follows:
- One ingress MAC ACL—if the
interface is in switchport mode
- One egress MAC ACL—if the
- One ingress IPv4 ACL
- One egress IPv4 ACL
- One ingress IPv6 ACL
Guidelines for all Layer 3
ACLs
(All supported devices) In addition to
the guidelines that apply to all ACLs, the following guidelines are relevant for
Layer 3 ACLs:
- In ingress Layer 3 ACLs, hard-drop rules
affect control protocol and MY IP packets.
- On Management interfaces, a hard-drop works the same as a
denyaction.
- Although L3 ACL deny rules do
not drop protocol packets, best practice is to define an explicit permit
rule for needed protocols.
SLX 9150, and
SLX 9250
devices) The following additional guidelines are relevant for Layer 3 ACLs:
- For tunnel-termination cases,
ingress ACLs are applicable for inner headers.
- For tunnel-origination cases,
egress ACLs are applicable for outer headers.
SLX 9540
and
SLX 9640 devices) The following additional guidelines are relevant for Layer 3
ACLs:
- In egress Layer 3 ACLs, deny and
hard-drop rules do not affect control protocol and MY IP
packets.
Guidelines for Layer 3 ACLs
applied to user interfaces
the previous guidelines, the following guidelines are relevant for Layer 3 ACLs
applied to user interfaces:
- There is an implicit "deny" rule at
the end of every Layer 3 ACL applied to a user interface. This denies all L3
streams that do not match any of the configured rules in the ACL.
- Traffic generated by the CPU—for
example, echo request packets—are not filtered by egress IPv4 ACLs.
SLX 9540
and
SLX 9640 devices) In addition to the previous guidelines, the following
guidelines are relevant for Layer 3 ACLs applied to user interfaces:
- Egress IPv4 ACLs are
applicable only for routed traffic.
Guidelines for ACLs applied to the
The following protection guards against malicious ICMP timestamp requests (icmp-type
13):
- ICMP timestamp requests and
responses are dropped by default.
- If an ACL with a permit icmp any
any rule is applied to the management interface, such a rule
permits ICMP timestamp requests. However, ICMP timestamp responses are
blocked.
are relevant for Layer 3 ACLs applied to the management interface:
- When an ACL is bound to the management
interface, ICMP packet types are implicitly permitted. An implicit deny entry is
programmed for the rest of the non-matching traffic.
- (Standard ACLs) Only packets with
TCP/UDP protocols are filtered for the configured match condition (for example,
SIP).
- (Standard ACLs) By default, TCP, UDP,
ESP, AH, and ICMP are allowed.
- (Extended ACLs) Applying a permit or
deny UDP ACL to the management interface enacts an implicit deny for TCP;
however, a ping will succeed.
deny ACL for a specific UDP port enacts an implicit deny for all other UDP
ports.
deny ACL for a specific TCP port enacts an implicit deny for all other TCP
ports.
- You can apply a maximum of two ACLs to
the management interface, as follows:
- Before downgrading firmware, unbind any
ACLs on the management interface.
If no ACLs are applied to the device
management interface, ICMP pings are allowed. In addition, the following default
rules are effective:
- seq 0 permit tcp any any eq
22
- seq 1 permit tcp any any eq
23
- seq 2 permit tcp any any eq
80
- seq 3 permit tcp any any eq
443
- seq 4 permit udp any any eq
161
- seq 5 permit udp any any eq
123
- seq 6 permit tcp any any
range 600-65535
- seq 7 permit udp any any
range 600-65535
Guidelines for rACLs
(All supported devices) The following
additional guidelines are relevant for all receive-path ACLs (rACLs):
- Interface ACLs and rACLs share the
same resource (database-table).
- In all rACLs, explicit and implicit
rules are processed in the following order:
- Explicit rules, in an order
determined by their seq
numbers.
- An implicit deny
any
my-ip rule that affects all other CPU-bound
traffic.
- Under inband management, you need
to include permit rules for your telnet/SSH access to the device.
SLX 9150, and
SLX 9250
devices) The following additional guidelines are relevant for all receive-path ACLs
(rACLs):
- IPv4 rACLs apply to multicast
datapath traffic only if multicast destination-IPs are explicitly specified
in rules.
- In an IPv4 rACL rule, if a
destination IP is not specified, my-ip (IP
addresses configured on any Layer 3 interface) is interpreted as the
destination IP. Such rules do not filter multicast traffic.
- Multicast traffic is first filtered
by rACLs, then by interface ACLs.
SLX 9540
and
SLX 9640 devices) The following additional guidelines are relevant for all
- rACLS are supported only for
unicast, routed traffic.
destination IP is not specified, matches apply to all IP addresses
configured on the device.
(All supported devices) The following guidelines are relevant for multiple rACLs:
- Multiple rACLs are supported
only in the default TCAM profile.
400 receive-path ACLs to a device, as follows:
- 200 IPv4 receive-path
ACLs
- 200 IPv6 receive-path
ACLs
- Supported sequence numbers
for rACLs range from 1 through 2047.
- If you apply an rACL to a
device without specifying a sequence number, numbers are assigned
automatically, as follows:
- The first rACL
applied to the device is assigned 10.
- Each additional rACL
applied is assigned an increment of 10 above the highest applied
sequence number.
The following table compares the effect of deny or hard-drop rACL matches
for different types of packets.
Table 1. Effect of deny and hard-drop
matches on different packet types
Packet type |
Deny or hard-drop match |
Control packets
Not dropped
Data packets
NA
My IP packets
(incl. ICMP, control or data)
Dropped
