Implementation flows for rACLs and interface ACLs
The implementation flows for Layer 3 interface ACLs and receive-path ACLs (rACLs) are similar.
For a comparison of rACLs and interface ACLs, refer to Interface ACLs and rACLs.
The following table displays the differential flows of implementation topics for Layer 3 interface ACLs and rACLs:
Table 1. Interface ACLs and receive-path ACLs
IPv4/IPv6 interface ACLs All IPv4/IPv6 ACLs IPv4/IPv6 rACLs
Layer 3 ACL configuration guidelines
One of the following procedures:
Applying Layer 3 ACLs to interfaces or globally Applying rACLs to devices
The above table indicates that there are no structural differences between Layer 3 interface ACLs and rACLs; you use identical procedures for all types. The implementation differences are as follows:
