Configuring a PBR policy
To configure a PBR, you must define the policies using ACLs and route map, then enable PBR globally or on individual interfaces. The device programs the ACLs into the session CAM on the interfaces and routes traffic that matches the ACLs according to the instructions in the route maps.
The following are the basic steps to configure a PBR policy:
  1. Configure ACLs that specify all the conditions required to match the desired packets to be routed using PBR.
    For details about configuring ACLs, see the "ACLs" section of this publication.
  2. Configure a route map that matches on the ACLs and sets the route information.
  3. Enable PBR by applying the route map on an interface.
