  Note the following basic support and limitations for TPVM.
	 Third-party applications
		  - Packet capture applications
- RESTful support to access SLX-OS
- perfSONAR
- ARPsponge
	 Third-party packages
		  - Packages installed by default on the TPVM
-  RESTful application: Chrome browser – GUI RESTful access
-  RESTful application: cURL – Command line RESTful access
- Tcpdump: Command line packet-capture utility
- Tshark: Command line packet-capture utility
- Wireshark: GUI packet-capture utility
- Datadog or Splunk – External analytics software service
 Extreme SLX-OS provides support for built-in applications (third-party packages shipped with the SLX-OS) that are listed in the
Extreme SLX-OS Management Configuration Guide.
		  - Extreme is committed to providing limited support for the interoperability of these applications with Extreme application interfaces.
- Extreme does not provide support for the application configuration, functionality, or deficiencies.
- Extreme does not provide any support for applications not listed in the
Hardware
		The TPVM has 4 GB of RAM and 240GB of solid-state disk (SSD) memory, which limits the amount of data captured through packet capture applications. To overcome this limitation, Extreme provides support for the Network File System (NFS) mount of an external drive.
