If you forgot the password for the VM
		root account, you can recover the default password.
For a list of the currently supported XGS
				devices, see the "Supported Hardware" topic.
				 Enter the
						reboot command.
				Select and enter the
						ONIE option.
				Select and enter the ONIE: Rescue option.
		  Define the root login value for the root recover environment variable.
			 ONIE:/ # bootenv VM_Root_Recover RootPasswd
				Enter the reboot command.
					ONIE:/ # reboot
ONIE:/ # discover: Rescue mode detected. No discover stopped.
Stopping: dropbear ssh daemon... done.
  The root account is now enabled. You can
					log in with the default fibrannepassword.
				If the SLX-OS CLI is available, you can recover the root account by using the
						SLX-OS CLI root enable command.
