| Command | Description |
| sudo apt-get update | Updates any dependency packages |
| sudo apt-get install curl | Installs the latest cURL package, or specifies a previous version number |
| sudo apt-get upgrade curl | Upgrades to the latest cURL package |
Google-chrome is a graphical user interface RESTful access utility. The following table lists useful installation and management commands
| sudo apt-get install google-chrome-stable | Installs the latest Google-chrome package, or specifies a previous version number |
| sudo apt-get upgrade google-chrome-stable | Upgrades to the latest Google-chrome package |
The Ifconfig and route utility commands are available by default in the Ubuntu/Debian package, and can be used without any additional package installation. The following table lists useful command options.
| ifconfig eth0 Net-IP-Addr netmask <Net-IP-Addr-Mask> | Checks interface status and statistics |
| route add -net Net-IP-Addr netmask Net-IP-Addr-Mask gw Gw-IP | Adds a route |
| route add default gw GW-IP | Adds a default gateway |
The Ethtool utility is used to get device information. The following table lists useful command options.
| sudo apt-get install ethtool | Installs the latest Ethtool package, or specifies a previous version number |
| sudo apt-get upgrade ethtool | Upgrades to the latest Ethtool package |
Tcpdump is a command line utility that is used for packet capture by means of libpcap. The following table lists useful command options.
| sudo apt-get install tcpdump | Installs the latest Tcpdump package, or specifies a previous version number |
| sudo apt-get upgrade tcpdump | Upgrades to the latest Tcpdump package |
Tshark is a command line utility from the Wireshark community that is used for packet capture by means of libpcap. The following table lists useful command options.
| sudo apt-get install tshark | Installs the latest Tshark package, or specifies a previous version number |
| sudo apt-get upgrade tshark | Upgrades to the latest Tshark package |
Wireshark is a GUI-based packet capture utility that is used for packet capture by means of libpcap. The following table lists useful command options.
| sudo apt-get install wireshark | Installs the latest Wireshark package, or specifies a previous version number |
| sudo apt-get upgrade wireshark | Upgrades to the latest Wireshark package |
