The tpvm deploy command is a
container command, rolling several SLX commands into one, to perform TPVM and Insight
Interface set up and configuration.
tpvm deploy command
performs the following installation and configuration operations:root@slx
SLX 20.1.2 and later releases have the flexibility to run eithertpvm-3.0.0 or
tpvm-4.0.0.
The default administrator passwords are different for each version. tpvm-3.0.0
uses
admin/password, and tpvm-4.0.0 uses
extreme/password.SLX 9540 is upgraded from hypervisor mode to bare metal mode.
tpvm deploy command:license eula accept
ADVANCED_FEATURES.tpvm-3.0.0 or
tpvm-4.0.0. Either one of the TPVM Debian package images can
be copied to /tftpboot/SWBD2900 and installed using tpvm install or
tpvm
deploy. However, it is recommended that only one TPVM Debian
package image (the desired version tpvm) exists under /tftpboot/SWBD2900 before executing tpvm install or
tpvm
deploy.Verify the presence of the TPVM firmware package in the SLXVM /tftpboot/SWBD2900
directory. If the latest version is not there, download before running the TPVM deploy command.
The tpvm deploy command begins with the standard TPVM installation.
eth0 and eth1.
When using tpvm install the default setting is eth0 and DHCP.
When using the tpvm deploy, the user can specify the interface to
use eth0 or eth1 and set it to use either DHCP or
specify an IP/netmask and gateway. In either case, the unused interface it set to
manual mode without any IP configuration.
The user can manually configure or override these settings by logging into the TPVM via ssh or tpvm console and manually modifying the linux network configuration.tpvm
deploy allows you to configure ssh access from the root user account on
the SLX-OS to TPVM without a password. For example:
root@SLX# ssh -o "StrictHostKeyChecking no" extreme@10.23.30.153When using the passwordless parameter, note the following:
tpvm deploy is
used, regardless of whether TPVM is reinstalled or retained from previous
install.The TPVM default user is admin with sudo privileges. The tpvm deploy command
configures TPVM so that sudo for this user does not ask for a password. Once set, this
parameter persists for the lifetime of the TPVM.
If not set, the default behavior requires a password for sudo activities, as
dictated by the Ubuntu 18.04 LTS Server Operating System.
The tpvm-4.0.0 package ships
with SLX-OS 20.1.2 and uses extreme/password as the default login credential. To automate the TPVM
setup and achieve one touch provisioning of TPVM, this optional parameter sets the
password for the TPVM admin user account. Once set, this parameter persists for the
Thetpvm-3.0.0 package can
be used/installed with SLX-OS 20.1.2. If you are using this TPVM package, note that
the default login credentials are admin/password.This option restarts the TPVM image automatically in subsequent reboots, such as an SLX-OS start on a Baremetal platform, or a HOST start on a VM-based platform.
After configuring the TPVM, tpvm deploy starts TPVM.
On the SLX-9150/9250, and the SLX-9650, a reboot of the SLX-OS reboots TPVM. On the
SLX-9450, an SLX-OS reboot does not affect TPVM, however if the HOST reboots for any
reason, TPVM also reboots.
