Setting state alerts and actions
System Monitor generates an alert when there is a change in the state from the default or defined threshold.
  1. Issue the configure terminal command to enter global configuration mode.
  2. To enable a RASLog alert (example: when the power supply is removed), enter the following command:
    device(config)# system-monitor power alert state removed action raslog
    There are no alerts for MM, compact-flash, or temp. There are no alert actions for SFPs.
