Configuring Y.1731 Performance Monitoring
To configure the Y.1731 performance monitoring feature on your Extreme device, perform the follow the task.
  1. Enter the global configuration mode.
    device# configure terminal
  2. Use the protocol cfm command to enter the CFM protocol configuration mode
    device(config)# protocol cfm
  3. Use the y1731 command to enter the Y.1731 configuration mode.
    device(config-cfm)# y1731
