SLX supports logging using syslog. This is extended to support
rsyslog over RELP.
Use the CLI logging utility enable relp to switch
between using syslog or rsyslog over RELP.
syslog is the default event message transmission protocol for SLX-OS.
SLX # config terminal SLX (config)#
Enable logging over RELP.
SLX (config)# logging utility enable relp SLX (config)#
When logging over RELP is enabled, logging over SYSLOG is automatically disabled and all event messages are transmitted over RELP.
Disable logging over RELP.
SLX (config)# no logging utility enable SLX (config)#
When logging over RELP is disabled, logging over SYSLOG is automatically enabled and all event messages are transmitted using SYSLOG.
When rsyslog over is RELP is configured as secured with TLS, the certificates that are used for securing SYSLOG are used by rsyslog over RELP.
After turning on logging over RELP, and when you use the login credentials of the SYSLOG server, then the same credentials are used for logging over RELP.
RELP mode does not support syslog-server host configuration. This configuration is automatically blocked in the RELP mode. An error message is displayed.
The following example shows the complete configuration for selecting the events to be logged and then enabling logging over RELP.
SLX# show run logg logging raslog console INFO logging auditlog class SECURITY logging auditlog class CONFIGURATION logging auditlog class FIRMWARE logging syslog-facility local LOG_LOCAL7 logging utility enable relp SLX#
