Configuring an event and actions for an action profile
To configure the Y.1731 performance monitoring feature on your Extreme device, perform the follow the task.
  1. Enter the global configuration mode.
    device# configure terminal
  2. Use the protocol cfm command to enter the CFM protocol configuration mode
    device(config)# protocol cfm
  3. Use the y1731 command to enter the Y.1731 configuration mode.
    device(config-cfm)# y1731
  4. Use the action-profile command to create an action profile.
    device(config-cfm-y1731)# action-profile myaction-profile
  5. Use the event command to configure an action profile event and associate actions.
    device(config-cfm-y1731-myaction-profile)# event avg-threshold actions all
