Extreme SLX-OS Management Configuration Guide, 20.5.2a
> Network Time Protocol (NTP)
Published September 2023
Preface
About This Document
What‘s New in this Document
Supported Hardware
Configuration Files
Displaying configurations
Backing up configurations
Configuration restoration
Tracking Configuration Changes
Turning off tracking of configuration changes
Managing flash files
Rebooting the device
Copying Support Save Files
Session connection
Telnet
SSH
Feature support for SSH
Enable or Disable SSH Service
Configuring a login banner
Configuring a static ethernet address
Force 1G connection speed on physical interfaces
Port management
SLX 100G ports
Configuring breakout mode
Port flap dampening
Port transition hold timer
Link fault signaling
Interface Ethernet ports
Displaying device interfaces
Chassis and host names
System clock
Setting the clock
Management VRFs
VRF reachability
Heartbeat between SLX and EFA
Heartbeat Setting
Zero Touch Provisioning
Using ZTP
ZTP configuration
MAC address aging
Hardware profiles
TCAM profiles
Specifying a TCAM profile
TCAM sharing
Enabling TCAM sharing
Counter profiles
Specifying a counter profile
FIB compression
Configuring FIB compression
OpenConfig-BGP Yang Module
Configuring Static PIC
Executing scripts from SLX-OS
Guest OS for TPVM
VM Access Management
VM access
SLX-OS CLI to VM access
Serial Console Access
Serial console to VM access
TPVM Console Access
TVPM address assignment
Insight Interface and TPVM
TPVM on the SLX 9150 series
Insight interface
Insight Interface Data Path
Inbound ACL-based mirroring
QoS egress scheduling
QoS rate shaping
SLX-OS VM commands
TPVM
perfSONAR
ARP sponge
TPVM Management
TPVM Package Information
Using the tpvm command
Using the tpvm config Command
Using tpvm deploy
Upgrading TPVM
Uninstalling TPVM completely
Docker containers
Linux containers
Update TPVM Gateway
IPv6 Support for TPVM
How it Works
Managing Snapshots
Upgrading TPVM
TPVM Migration
Measured Boot
Measured Boot
Verifying Measured Boot
Remote Attestation
Remote Attestation
Configure Remote Attestation
Configuring NTP
Authenticating an NTP server
SNMP
SNMP overview
Basic SNMP operation
SNMP community strings
SNMP groups
SNMP users
SNMP views
SNMP server hosts
SNMP Engine ID
SNMP source interface
Configuring SNMPv2
Configuring SNMPv3
LLDP
LLDP overview
Layer 2 topology mapping
Configuring and managing LLDP
Disabling LLDP globally
Configuring LLDP profiles
Displaying LLDP information
Account and Password Recovery
Recover the root login account
Recover the root password when shell prompt is available
Recover the root password when ONIE is available
Force Password Age Out
Python overview
Python scripts
Python scripts and run-logs
Event-handler script
Python event-management
Activating an event-handler
Configuration Rollback
Configuring rollback
