It is assumed that your infrastructure is set up with a gNMI client. Its configuration is beyond the scope of this document.
SLX-OS provides a simple switch to enable OpenConfig Telemetry Support. By default, this feature is disabled and must be enabled.
SLX#
SLX# config terminal
SLX (config)#
operational-state syncup enable <module> command to enable
all the supported modules or a specific module.
The operational-state syncup enable all command enables support for
all the modules
Use the specific module switch to enable OpenConfig Telemetry for that module.
SLX (config)# operational-state syncup enable ?
Possible completions:
All Enable oper db syncup for all modules
Bgp Enable oper db syncup for bgp
Interface Enable oper db syncup for interface
Platform Enable platform specific oper db syncup
SLX (config)#
The following example enables OpenConfig Telemetry Support for the BGP module.
SLX (config)# operational-state syncup enable bgp
SLX (config)#
