For Remote Attestation to work, Measured Boot must be enabled. To learn more about Measured Boot, see Measured Boot in this document.
Remote Attestation is supported on Extreme 8720 and Extreme 8520 devices.To configure Remote Attestation do the following:
SLX # configure terminal
SLX (config)#
SLX (config)# measure-boot enable
SLX (config)#
SLX (config)# remote-attestation
SLX (config-remote-attestation)#
SLX (config-remote-attestation)# registrar-server 10.1.1.1 use-vrf default-vrf
SLX (config-remote-attestation-10.1.1.1/default-vrf)#
SLX (config-remote-attestation-10.1.1.1/default-vrf)# registrar-port
SLX (config-remote-attestation-10.1.1.1/default-vrf)# exit
SLX (config-remote-attestation) #
SLX(config-remote-attestation)# agent-uuid ?
Possible completions:
<1-100> UUID of the device.[auto]
SLX(config-remote-attestation)# agent-port ?
<Choose the port number in the range 0 - 65535>
SLX (config-remote-attestation) # agent-enable
SLX (config-remote-attestation) # exit
SLX (config)#
SLX (config)# exit
SLX #
