To display the global LLDP status, use the show lldp command.
device# show lldp
LLDP Global Information
system-name: SLX
system-description: Extreme BR-SLX9540-4 Router
description: Extreme-LLDP
State: Enabled
Mode: Receive/Transmit
Advertise Transmitted: 30 seconds
Hold time for advertise: 120 seconds
Tx Delay Timer: 1 seconds
Transmit TLVs: Chassis ID Port ID
TTL Port Description
System Name
To display LLDP status for an Ethernet interface, use the show lldp interface ethernet command.
device# show lldp interface ethernet 0/18
LLDP information for Eth 0/18
State: Enabled
System Name
To display the LLDP neighbor information, use the show lldp neighbors command. This command allows you to display the information for all Ethernet interfaces, a specific interface, or detailed neighbor information.
The following example displays the LLDP neighbor information for all interfaces.
device# show lldp neighbors Local Port Dead Interval Remaining Life Remote Port ID Remote Port Descr Chassis ID Tx Rx System Name Eth 0/18 120 102 Ethernet 0/25 Eth 2/25 768e.f807.6000 653 652 R6 Eth 0/21 120 108 Ethernet 0/21 Eth 1/21 768e.f807.6000 653 652 R6 Eth 0/40 120 110 Ethernet 0/50 Eth 1/50 768e.f807.6000 653 650 R6 Eth 0/43 120 102 Ethernet 0/51 Eth 2/51 768e.f807.6000 653 652 R6 Eth 0/50 120 102 Ethernet 0/23 Eth 2/23 768e.f807.6000 653 611 R6
The following example displays the LLDP neighbor information for Ethernet interface 0/18.
device# show lldp neighbors interface ethernet 0/18 Local Port Dead Interval Remaining Life Remote Port ID Remote Port Descr Chassis ID Tx Rx System Name Eth 0/18 120 115 Ethernet 0/25 Eth 0/25 768e.f807.6000 655 654 R6
The following example displays the detailed LLDP neighbor information for Ethernet interface 1/18.
device# show lldp neighbors interface ethernet 0/18 detail Neighbors for Interface Eth 0/18 MANDATORY TLVs =============== Local Interface: Eth 0/18 (Local Interface MAC: 768e.f805.5816) Remote Interface: Ethernet 0/25 (Remote Interface MAC: 768e.f807.610d) Dead Interval: 120 secs Remaining Life : 118 secs Chassis ID: 768e.f807.6000 LLDP PDU Transmitted: 656 Received: 655 OPTIONAL TLVs ============== Port Interface Description: Eth 0/25 System Name: R6
To display the LLDP statistics for all interfaces or a specific interface, use the show lldp statistics command.
The following example displays the statistics for Ethernet interface 0/18.
device# show lldp statistics interface ethernet 0/18 LLDP Interface statistics for Eth 0/18 Frames transmitted: 659 Frames Aged out: 0 Frames Discarded: 0 Frames with Error: 0 Frames Recieved: 657 TLVs discarded: 0 TLVs unrecognized: 0
If you do not include the interface ethernet option, the command displays the statistics for all interfaces.
