Use this procedure for applying a Layer 3 ACL to the management interface, using the {ip | ipv6} access-group command.
If an explicit "deny ip any any" IP rule is applied to the management interface, that IP rule has priority over any TCP or UDP rules. Any incoming TCP packets that match that IP rule are dropped because the TCP packet has an IP header.
device# configure terminal
device(config)# interface management 0
device(config-Management-0)# ip access-group stdACL3 in
device(config-Management-0k)# ipv6 access-group stdV6ACL1 in
