Remote Authentication Dial-In User Service (RADIUS) server accounting is supported for recording information about user activity.
System event accounting is not supported.When you configure RADIUS accounting on a device, information is sent to the RADIUS accounting server when specific events occur; for example, when a user logs in to the device.
RADIUS server accounting can be enabled and used regardless of whether authentication is performed locally, on a RADIUS server, or on a TACACS+ server. However, RADIUS accounting only takes place after successful authentication.
In command accounting, commands with a partial timestamp are not accounted.
By default, RADIUS server accounting is disabled. Prior to enabling RADIUS server accounting, at least one RADIUS server must be configured.
For command accounting, the Vendor Specific Attribute (VSA) Brocade-Cmd must be added on RADIUS server.
Before downgrading to a software version that does not support RADIUS accounting, both login and command accounting must be disabled.
