The following steps configure an IPv6 PBR by setting an IPv6 address as the next hop in the route map.
This task uses access-control lists (ACLs). For details about configuring ACLs, see the "ACLs" section of this publication.device# configure terminal
device(config)# ipv6 access-list standard 99 device(conf-ip6acl-std)# permit any
device(conf-ip6acl-std)# exit
device(config)# route-map test-route permit 99
device(config-route-map-test-route/permit/99)# match ipv6 address acl 99
device(config-route-map-test-route/permit/99)# set ipv6 next-hop 2001:db8:0:0:0:ff00:42:8329
device(config-route-map-test-route/permit/99)# exit
device(config)# interface ethernet 1/1 device(conf-if-eth-1/1)# ipv6 policy route-map test-route
device(config)# interface Ve 1 device(config-if-Ve-1)# ipv6 policy route-map test-route
The following example shows the configuration steps to configure an IPv6 PBR by setting an IPv6 address as the next hop in the route map.
device# configure terminal device(config)# ipv6 access-list standard 99 device(conf-ip6acl-std)# permit any device(conf-ip6acl-std)# exit device(config)# route-map test-route permit 99 device(config-route-map-test-route/permit/99)# match ipv6 address acl 99 device(config-route-map-test-route/permit/99)# set ipv6 next-hop 2001:db8:0:0:0:ff00:42:8329 device(config-route-map-test-route/permit/99)# exit device(config)# interface ethernet 1/1 device(conf-if-eth-1/1)# ipv6 policy route-map test-route device(conf-if-eth-1/1)# end
