When you create ACL rules for which you want to enable logging, you must include the log parameter.
device# configure
device(config)# ipv6 access-list extended ipv6_acl_1
device(conf-ip6acl-ext)# seq 20 deny ipv6 2002:2003:1234:1::/64 2001:3001:1234:1::/64 log
device# show access-list-log buffer Frames Logged on interface Eth 2/1 : ------------------------------------ Frame Received Time : Wed Apr 6 2016 8:15:4 Ethernet, SrcMAC : 00:24:38:9b:cf:21, DstMAC: 76:8e:f8:05:70:14 Ethtype : 0x86dd Protocol Type : IPV6 SrcIP : 26::1 DstIP : 25::1 Interface : Eth 1/16 Flow-ID : 63800000 Payload Length : 1c6 Nxt Header Type : 6 (TCP) Hop-Limit : 63 packet(s) repeated : 11565 Ingress Deny Logged ----------------------------------------------------------------------------
If an ACL with rules that contain the log keyword is applied to the management interface, logs are not recorded for that ACL.
