SLX # configure terminal SLX (config)# bmc SLX (config-bmc)#
Configuration of each User ID must be done separately from within its configuration mode.
Only the user with the User ID 2 can be configured. Though the command allows configuration of other User IDs, those changes are not applied on the BMC.
SLX (config-bmc)# user-id 2 SLX (config-bmc-user-2)#
Each User ID has its own configuration mode. Configurations made within this mode is only applicable to that specific User ID.
SLX (config-bmc-user-2)# password testing123 SLX (config-bmc-user-2)#
SLX (config-bmc-user-2)# do show bmc password-status 2 Status: Set SLX (config-bmc-user-2)#
This example shows the configuration of a new password for the User ID 2.
SLX # configure terminal SLX (config)# bmc SLX (config-bmc)# user-id 2 SLX (config-bmc-user-2)# password testing123 SLX (config-bmc-user-2)# exit SLX (config-bmc)# exit SLX (config)# exit SLX #
The following example shows the output when you try to assign a password with length shorter than the minimum password length
SLX # configure terminal SLX (config)# bmc SLX (config-bmc)# user-id 2 SLX (config-bmc-user-2)# password test123 % Error: BMC password length should be 8-20 characters SLX (config-bmc-user-2)#
You can also use the do show running-config bmc user-id command to view the encrypted form of the password.
SLX (config-bmc-user-2)# do show running-config bmc user-id bmc user-id 2 password $9$VaXhc9WCy+1IwRU2ZaS2vQ== ! ! SLX (config-bmc-user-2)#
