Configure BMC Management Interface IP Address
Keep the IPv4 address, the Netmask, and the Gateway IPv4 address that is required to be configured, ready.
SLX-OS configures the following static IP 192.168.11.1/24 and default gateway 0.0.0.0 by default.
To configure the BMC Management Interface:
  1. Navigate into the BMC Management Interface context.
    SLX # configure terminal
    SLX (config)# bmc
    SLX (config-bmc)#
    Only the BMC Management Interface with interface ID of 0 can be configured.
    You are now within the BMC configuration mode.
  2. From within the BMC configuration mode, navigate into the BMC Management Interface configuration mode.
    SLX (config-bmc)# interface management 0
    SLX (config-bmc-mgmt-0)#
    You are now within the BMC Management Interface configuration mode.
  3. Configure the IPv4 address for the BMC Management Interface.
    • To configure the BMC Management Interface to receive the IPv4 address from a remote DHCP server, use the following command.
      SLX (config-bmc-mgmt-0)# ip dhcp
    • To configure the BMC Management Interface's IPv4 address manually, execute the following command:
      SLX (config-bmc-mgmt-0)# ip address 10.9.9.23/24 gw 10.9.9.2
    The IPv4 address for the BMC Management Interface is either automatically assigned or manually configured.
  4. Optional: Verify by issuing the do show bmc interface management 0 ip command.
    SLX (config-bmc)# do show bmc interface management 0 ip
     IP Address Source  : Static Address
     IP Address         : 10.9.9.23
     Subnet Mask        : 255.255.255.0
     MAC Addres         : 00:04:96:b8:41:b8
     Default Gateway IP : 10.9.9.2
This example shows the configuration of DHCP for the BMC Management Interface.
SLX (config)# bmc
SLX (config-bmc-mgmt-0)# ip DHCP
SLX (config-bmc-mgmt-0)# exit
 IP Address Source  : DHCP Address
 IP Address         : 192.168.0.120
 Default Gateway IP : 0.0.0.0
This example shows the default configuration of a static IPv4 address. This IP address is assigned to the interface automatically and will be retained unless changed.
SLX (config)# bmc
SLX (config-bmc-mgmt-0)# no ip DHCP
 IP Address         : 192.168.11.1
