To enable or disable out-of-band access to BMC Management Interface:
SLX # configure terminal SLX (config)# bmc SLX (config-bmc)#
Configuration of each BMC Management Interface must be done separately from within its configuration mode.
Only the BMC Management Interface with interface ID of 0 can be configured.
SLX (config-bmc)# interface management 0 SLX (config-bmc-mgmt-0)#
If you need to shutdown the interface to prevent out-of-band access, use the shutdown command.
SLX (config-bmc-mgmt-0)# shutdown SLX (config-bmc-mgmt-0)#
If the interface is in the shutdown state, you can enable it by executing the no shutdown command.
SLX (config-bmc-mgmt-0)# no shutdown SLX (config-bmc-mgmt-0)#
This example shows how to shutdown the BMC Management Interface to prevent out-of-band access.
SLX # configure terminal SLX (config)# bmc SLX (config-bmc)# interface management 0 SLX (config-bmc-mgmt-0)# shutdown SLX (config-bmc-mgmt-0)# exit SLX (config-bmc)# exit SLX (config)# do show bmc interface management 0 status Status: Disabled
This example shows how to enable a shutdown BMC Management Interface to enable access to it from out-of-band ports.
SLX # configure terminal SLX (config)# bmc SLX (config-bmc)# interface management 0 SLX (config-bmc-mgmt-0)# no shutdown SLX (config-bmc-mgmt-0)# exit SLX (config-bmc)# exit SLX (config)# do show bmc interface management 0 status Status: Enabled
