Reset BMC Configuration to Factory Defaults
To reset the device's BMC configuration back to its factory defaults:
  1. From the Executable Mode, execute the command bmc factory reset.
    SLX# bmc factory reset
      SLXOS needs to be restarted for normal operations, after bmc factory reset.
      Do you want to continue? (y/n):
  2. Enter y to proceed with restarting the device and resetting the BMC configuration to factory defaults.
      Do you want to continue? (y/n): y
    SLX#
  3. Use the reload command to force the device to reboot.
    SLX# reload
    The device starts to reboot and post reboot, the BMC configuration is reset to its factory defaults.
The following example shows the reset to BMC's factory default settings.
SLX# reload
