Installing TPVM Using tpvm deploy
This task describes the use of the tpvm deploy command and parameters.
  1. Switch to the Linux shell from the SLX-OS CLI.
    device# start-shell
  2. Enter the Linux admin user shell.
    [admUser@SLX]# su
    password: <password>
    The default password is "fibranne".
  3. Remove the existing TPVM package at the following path in the device's SLX-OS VM, at the Linux shell login prompt.
    [admUser@SLX]# rm -rf /tftpboot/SWBD2900/vm-swbd2900-*.deb
  4. Using SCP or FTP, copy the new TPVM package that is compatible with the SLX-OS release from the release server, and copy it to the SLX-OS VM /tftpboot/SWBD2900/ folder.
  5. Return to the SLX-OS CLI shell.
    root# exit
    admin# exit
  6. Stop TPVM if it is running.
    device# tpvm stop
  7. Uninstall existing TPVM firmware.
    device# tpvm uninstall
  8. Use tpvm deploy to configure the network and management settings, and install TPVM.
    device# tpvm deploy mgmt ipaddr 10.25.101.121/22 gw 10.25.100.1 admin-pwd mypassword
    confirm mypassword
    Starting TPVM deploy CLI, please DO NOT hit CTRL+C
    Tpvm install started
    ..Tpvm is installed
    Tpvm set_ip succeeds
    Tpvm password succeeds
    auto-boot enable succeeds
    Tpvm is started
    Above is one example of using TPVM deploy. The following are additional examples.
    • Eth0 with DHCP and passwordless login
      device# tpvm deploy interface mgmt ip-addr dhcp pwdless
    • Eth0 with static IP and passwordless login.
      device# tpvm deploy interface mgmt ip-addr 192.168.1.1/24 pwdless
    • Eth0 with static IP, default gateway and passwordless login
      # tpvm deploy interface mgmt ip-addr 192.168.1.1/24 gateway 192.168.1.100
          pwdless
    • Eth1 with static IP and passwordless login
      device# tpvm deploy interface insight ip-addr 10.10.10.1/24 pwdless
    • Eth1 with static IP, default gateway and passwordless login
      device# tpvm deploy interface insight ip-addr 10.10.10.1/24 gateway 10.10.10.100
          pwdless
    • Eth1 with static IP, default gatway, passwordless login and new TPVM password setup
      device# tpvm deploy interface insight ip-addr 10.10.10.1/24 gateway 10.10.10.100 pwdless password
            admin123 admin123
    • Eth0 with static IP, default gateway, passwordless login and new TPVM password setup
      device# tpvm deploy interface mgmt ip-addr 10.10.10.1/24 gateway 10.10.10.100 password admin123
            admin123
    • Eth1 with Static IP, default gateway
          10.10.10.100
