Link fault signaling
The SLX platform supports Link Fault Signaling (LFS) detection for interface types of 10G, 40G, 100G, and 40G breakout ports. It detects local and remote faults.
LFS is not supported in 1G mode.
When the device detects a local fault, it returns a remote fault to the link partner. When the device detects a remote fault, it returns an idle state.
A port's physical link detection is independent of LFS detection. When either of these link fault signals is detected, the following behaviors occur:
You can enable or disable LFS globally and on the interface level for both RX and TX directions:
