This section addresses details of the insight interface port on different Extreme SLX platforms.
Extreme SLX 9540
The following is an example configuration.
device(config)# hardware
device(config-hardware)#
device(config-hardware)# connector 0/48
device(config-connector-0/48)# [no] insight mode
device(config)# interface port-channel 20
device(config-Port-channel-20)# insight enable
Extreme SLX 9640
Extreme SLX 9150 and SLX 9250
The SLX 9150 and SLX 9250 assign the following ports for VM access. These ports are exclusive use only for VM access.
  • SLX 9150T : 0/73
  • SLX 9150: 0/81
  • SLX 9250: 0/129
