Port flap dampening
Port flap dampening allows you to configure a wait period before a port, whose link goes down then up, becomes enabled.
If the port link state toggles, from down to up or from up to down, for a specified number of times within a specified period, the interface is physically disabled for the specified wait period. Once the wait period expires, the port‘s link state is re-enabled. However, if the wait period is set to zero (0) seconds, or you want to re-enable the port before the wait period expires, the port must be manually re-enabled.
